diyAudio Sponsor
Old 28th June 2006, 06:04 PM   #1
jaykick is offline jaykick  United States
Default Output Impedance
Forgive me if this has been address many times before, but I'm using a circa 1980 internet connection and dont have enough time to search (cargo ship in the ocean).
Am I correct in understanding that if I am using a 3500ohm out put transformer, with 4 ohm output, into a 2 ohm load, the 300B is actually going to see a 1750 ohm load? And if so, this is still fine for a 300B? Or should I go with a 5k output transformer?
thanks,
Jay
Old 28th June 2006, 07:16 PM   #2
Giaime is offline Giaime  Italy
Giaime's Avatar
Send a message via MSN to Giaime
Hello Jay!
You're correct, the 300B is going to see 1750ohm load. Bad thing, too low with strong distortion.
I suggest you find a proper output transformer, with a 2ohm secondary winding, or you could use a 6-8k one with the 4ohm secondary.
May I ask why are you trying to drive a 2ohm load with a 300B?
Old 28th June 2006, 07:16 PM   #3
kevinkr's Avatar
No this isn't fine for a 300B, using a 5K transformer would help, OTOH getting a transformer wound that has a 2 ohm secondary tap might be better still due to the dcr of a nominally 4 ohm secondary.
I'm sure electraprint would do this, and ASL in Hong Kong did it for some amplifiers I designed and had them build oem..
www.kta-hifi.net
Old 28th June 2006, 07:37 PM   #4
tubemaster's Avatar
Default Re: Output Impedance
Hi Jay,
Yes, this is correct. But bear in mind that a loudspeaker is not a pure resistive load but a reactive one too which makes matters a little more complex.
This is a not an easy question! The 300B will not be damaged but the sound will be effected. Increasing the load will raise the distortion but also the available output power. Attached is a diagram showing the relations between load, output power and distortion in the 300B as published by Western Electric.
On the other hand a transformer with a 5K primary has some draw backs as compared to a transformer with 3.5K impedance in that its winding capacity will be larger which can effect high frequency response possibly resulting in a sound less clear and bright.
Besides it really also depends a lot on the individual output transformer, the type of 300B used and most of all on the characteristics of the speaker.
You might consider getting a Sowter SA08 output transformer which is very good indeed and can be configured to a 1 ohm secondary connection which will put you on the really safe side in halfing the load to 7K giving a little less power and a lot less distortion!
Michael
Old 28th June 2006, 10:01 PM   #5
Giaime's Avatar
Default Re: Re: Output Impedance
I'm sure you meant "decreasing the load".
Old 28th June 2006, 10:12 PM   #6
Default Re: Re: Re: Output Impedance
I am no valve expert, but I think he referred to increasing the current demand, while you refer to decreasing the load impedance, which are the same thing.
Old 29th June 2006, 09:24 AM   #7
tubemaster's Avatar
Hello,
I meant increasing the load by decreasing the load resistance!
Michael
Old 29th June 2006, 09:33 AM   #8
Giaime's Avatar
Oh yes Michael,
in fact you're right. It's a bad practice to confuse "load" with "load resistance".
My fault
Old 29th June 2006, 12:15 PM   #9
Yvesm is offline Yvesm  France
Yvesm's Avatar
Hey, where did you find THAT
Obviously a very poor tube for audio output use
Yves.
Old 29th June 2006, 02:40 PM   #10
tubemaster's Avatar
Yves.
Hello Yves,
why do you think that?
The diagram shows a distortion of 6% with 7.5 Watt at a load of 3.5K. That is very good! There aren't so many tubes that achieve this when operated in single ended triode mode without negative feedback!
Michael
3C24 in a SE output stage - output transformer impedance recommendation !!! aldovan Tubes / Valves 15 6th September 2008 10:18 AM
Output impedance overdrajv Tubes / Valves 8 5th March 2008 05:54 PM
Can An Output Transformer Change A Voltage Amp's Output Impedance From 0.1 To 47 Ohms kelticwizard Everything Else 11 25th March 2007 05:17 AM
Output Impedance? ble0t Parts 4 19th January 2006 05:45 PM
Low output impedance pre miguel2 Tubes / Valves 13 23rd July 2003 09:51 AM
Page generated in 0.12787 seconds (80.36% PHP - 19.64% MySQL) with 11 queries
