Triode connecting a pentode? - Page 2 - diyAudio
Old 30th June 2006, 09:28 PM   #11
Tubes4e4's Avatar
Hi tubelab,
just to clarify, I was not talking about the difference between strapping g3 to cathode (this is quite evident for power pentodes and almost moot for small signal ones, and was mostly covered in the previous thread you mentioned, indeed), but the difference a small value resistor would make in the g3-to-plate connection compared to a simple wire.
Tom
If in doubt, just measure.
Old 30th June 2006, 10:12 PM   #12
Sherman is offline Sherman  United States
Originally posted by Tubes4e4
Hi tubelab,
just to clarify, I was not talking about the difference between strapping g3 to cathode ...
Tom
Tom
One amp by someone not an expert hardly qualifies as proof of anything but I'll toss in my experience anyway. Take it for what it is, one person's experience with one amp.
I built a stereo EL84 amp running (IIRC) 350V B+. I put in a switch so that I could switch between pentode and triode. I initially just ran a wire from the switch to the plate.
Pentode mode worked just fine (but sounded like a pentode EL84 ) but triode mode caused it to "warble". Not exactly like an ocillation but maybe it was. This occured at virtually any volume setting. Anyway it could not be run in triode mode.
I put a 100 ohm resistor between G3 and the plate and all was well. It doesn't oscillate at any volume and seems perfectly stable.
So in my experience a 100R resistor between G3 and the plate does in fact make the amp more stable in triode mode.
(Maybe it was a poor amp design, maybe it had other faults, whatever, but the resistor made a difference.)
--Sherman
Old 30th June 2006, 11:07 PM   #13
Tubelab_com's Avatar
Maybe I was trying to answer everyone's question at once. I was trying to answer the original question (G3 to plate, or cathode) by saying that both are possible, and there are strong opinions on both sides.
As to the resistor, I used to use a direct wire from plate (or the mode switch) to the screen. I ran into a wierd oscillation problem with some EL-34's in UL mode where the tube would briefly oscillate during a very short period at the peak of the voltage swing (max plate voltage) when driven hard by a low frequency (100Hz) sine or triangle wave. I have since used a small (100 ohm) value resistor in series with the screen grid installed right at the socket pin.
In some Mullard literature a 1K resistor was recommended for UL use in push pull applications. I tried this with JJ tubes in SE UL and it just lowered the power a little bit, without making much difference in sound or distortion measurements. I did find out that the small metal film resistors do not live long in this application. They can't handle the peak currents that occur when the amp is driven to clipping.
Tubelab, it's 5 year mission. To explore strange new tubes, to seek out new circuits and topologies, to boldly go where no tube has gone before......
Old 1st July 2006, 09:39 AM   #14
Tubes4e4's Avatar
Hi Sherman,
I don´t doubt that such a resistor may be useful as a parasitic oscillation stopper in this certain connection
And not having parasitics certainly sounds better
Tom
Old 1st July 2006, 04:37 PM   #15
Brian Beck's Avatar
The other side of my brain is RF-oriented. For those keeping track that leaves me with 50% of a brain for audio. Oh well…
Anyway, we sometimes used parasitic suppressors in the design of RF power amps. These are typically low value resistors in PARALLEL with a small air core inductor. These twin components are often placed in series with the plate/drain of the power device, before the tuned output circuits. At RF the choke becomes a high reactance and you have only the resistance in line, which acts to damp any unplanned resonances (parasitics). At low frequencies (DC in the case of RF designs) the resistor is shorted so that it doesn’t drop any DC voltage which would waste power.
Now for audio, you could place such a parasitic suppressor in the G2 or G3 lead to suppress oscillation. No, I haven’t needed to try this, since my power amp projects usually don’t have screens or suppressors to begin with. Use a carbon comp resistor, at least 1/4 watt and maybe 1/2 watt. Pick a value as discussed above. Solder an enameled magnet wire to one resistor lead close to the body. Using the resistor body as a form (essentially an air-core magnetically), wrap turns around it in a spiral and then solder the other side to the other lead close to the body. The exact values needed for the R and the small L are subject to experimentation, but should work over wide ranges for either part.
So what would we have achieved? At all audio frequencies and even well above, the inductor is nothing more than a short circuit. So, for audio, there is no resistor in line at all, just a wire. At VHF and UHF frequencies, the inductor approaches an open circuit since the inductive reactance becomes high. So, RF sees just a resistor, which damps any tendency to sing. It is possible under the right (wrong) circumstances for this little inductance to create a new resonance that could encourage oscillation, so experimentation is in order. There are too many variables among the parts, circuits and layouts to predict exactly. But if it can be made to work, it might be the best of both options rolled into one.
Brian
Old 3rd July 2006, 06:10 AM   #16
Miles Prower's Avatar
Same thing I did with PP 807s operating in pentode mode: 100R; 2W carbon comp inserted into coils (N= 10; ID= 7/16 in.; #18 space wound) attached right at the plate caps. With screen stoppers, there is no tendency to produce RF oscillations, either continuous or damped.
There are no foxes in atheistholes
www.dolphin-hsl.com
6X8 Pentode/Triode Musings Eli Duttman Tubes / Valves 37 31st January 2010 04:36 AM
PP-Triode , PP-UL , PP-Pentode-strapped-as-Triode percy Tubes / Valves 23 22nd January 2007 01:36 AM
Anyone tried UL or Triode connecting the $140 kit ? percy Tubes / Valves 3 21st December 2004 04:26 AM
SE Pentode or PP Triode ? percy Tubes / Valves 37 8th October 2004 11:21 AM
triode=>pentode Lico Tubes / Valves 3 7th April 2004 08:08 PM
Copyright ©1999-2017 diyAudio
