Edcor P-P Transformers
Old 27th June 2006, 10:06 PM   #1
wrenchone is offline wrenchone  United States
wrenchone's Avatar
Default Edcor P-P Transformers
I'm thinking of using the 6GF7A in 2 flavors of amp - a low wattage single ended and a ~10W push-pull. I'm looking for cheap iron for both projects. I've seen consinderable discussion of the inexpensive Edcor single ended transformers (I'll probably use them for the SE amp), but not of their push-pull line. How do these sound compared to the usual contenders?
Old 27th June 2006, 11:02 PM   #2
anatech is offline anatech  Canada
anatech's Avatar
Hi wrenchone,
I am pretty sure Tubelab.com has played with them. I'm just waiting until he drops in.
-Chris
Old 27th June 2006, 11:26 PM   #3
rdf is offline rdf  Canada
rdf's Avatar
Have you seen this site?
http://www.angelfire.com/electronic/...0_W_4_6L6.html
Ears aren't microphones.
Old 28th June 2006, 12:30 AM   #4
Tubelab_com is offline Tubelab_com  United States
Tubelab_com's Avatar
No, it wasn't me. The only Edcors that I have tried are the cheap SE's. I have a pretty good selection of P-P transformers to play with, so I haven't bought any in several years.
Tubelab, it's 5 year mission. To explore strange new tubes, to seek out new circuits and topologies, to boldly go where no tube has gone before......
Old 28th June 2006, 12:40 AM   #5
wrenchone's Avatar
I've seen the site with the comparisons for the 50W 6L6 circuit - interesting. However, I'm more interested in how the $17 Edcor
P-P transformers sound. I guess I'll be finding out for myself...
Old 28th June 2006, 12:49 AM   #6
anatech's Avatar
Gee tubelab.com,
I thought for sure you must have with all the amps you've played with. Oh well, my mistake.
You sure are a lucky man! Just not enough time I guess.
-Chris
Old 28th June 2006, 09:30 AM   #7
ray_moth is offline ray_moth  Indonesia
diyAudio Moderator Emeritus
ray_moth's Avatar
I keep referring people to Max Robinson's site - I must be sounding like a cracked record by now! However, he has been experimenting with Edcors recently (PP only, he's not really into SE) and he, at least, seems pretty pleased with them. Here is his ultralinear amp design URL, in his "Fun with Tubes" web site.
Old 28th June 2006, 01:08 PM   #8
Hojvaelde is offline Hojvaelde  Denmark
I know Edcor but they will not send to Europe.
They only want to send the trafo's by airfrigth so the frigthbill is higher than the bill for the trafoes.
Benny
Old 28th June 2006, 05:13 PM   #9
wrenchone's Avatar
Max Robinson's site evaluates a transformer from Edcor's "expensive" push-pull line. I'm interested in the cheap product line, notably the 8k 10W transformer, the smallest in that series. This translates to 2k/side, and may allow one to squeeze 10W out of a pair of 6GF7s pushed very hard. (Can that little triode actually dissipate 10W?). Given the price for the "budget series" Edcor transformers, the experiment will be relatively painless for the pocketbook.
Old 30th June 2006, 03:39 AM   #10
wrenchone's Avatar
Just to throw a small wrench in the works, I'm thinking of using a small switcher tp power the single ended 6GF7 amp. What I envision is a fairky large "lump in cord" AC transformer outside the box. Rectified and filtered, this would power the filaments via a current source, and also power a DC-DC converter for HV and bias similar to the ones that drive CCFL tubes.
Edcor P-P TransformersHide this!Advertise here!
Edcor Transformers whitelabrat Tubes / Valves 23 9th September 2011 02:16 AM
FS: Edcor GXSE15-8-5k Output Transformers Brand New Pair nic6paul Swap Meet 2 12th April 2009 08:55 PM
Edcor Transformers Sal Brisindi Tubes / Valves 18 11th November 2007 01:08 PM
Edcor transformers in Australia? jnb Parts 8 31st July 2007 05:47 AM
Edcor OPT's bloozestringer Tubes / Valves 23 3rd January 2007 05:27 AM
