diyAudio Sponsor
Old 30th June 2006, 07:01 PM   #11
tubelab.com's Avatar
I'm interested in the cheap product line, notably the 8k 10W transformer, the smallest in that series
Well, I got to thinking, and I just ordered a pair of them (along with a pair of the big SE transformers), so I will wire them up to a pair of Push - Pull 6AQ5's in UL when I get them. They should generate nearly the 10 watts needed to test their limits.
Too much power is almost enough! Turn it up till it explodes - then back up just a little.
Edcor Transformers whitelabrat Tubes / Valves 23 9th September 2011 02:16 AM
FS: Edcor GXSE15-8-5k Output Transformers Brand New Pair nic6paul Swap Meet 2 12th April 2009 08:55 PM
Edcor Transformers Sal Brisindi Tubes / Valves 18 11th November 2007 01:08 PM
Edcor transformers in Australia? jnb Parts 8 31st July 2007 05:47 AM
Edcor OPT's bloozestringer Tubes / Valves 23 3rd January 2007 05:27 AM
Page generated in 0.05934 seconds (62.32% PHP - 37.68% MySQL) with 10 queries
