| diyAudio Sponsor | ||
Anyone know of a good metalwork shop in the greater NYC area?
I have a 16 gauge steel chassis in mint condition that I need to modify to fit my preamp design. As I don't have a lot of high-quality tools (just a jig saw and a drill), I am a bit wary of cutting into the chassis myself. I can easily lay out the work I need done (aka the various holes punched out of the top for the tubes and caps, the bottom cut out, etc). Thanks. |
#2 |
I'd be interested as well...
#3 |
You can make a chassis with wood base and metal plate!!
See the photo who I have attached! You can make a wood base and put a metal on the top. The metal can from of one lateral of computer AT case! You can cut it with a Dremel or other mini-retifier... This is very simple! What do you think about my idea?
Brazilian Tube Amp Builder. |
#4 |
Hey mod_evil.....
You make that wood chassis case ??? If you did ..it is nice clean work.. Looks good CHris |
#5 |
No, I didn't make this wood case. I have used this photo to have a refference to make my chassis!
You can make similar with a wood baseboard!!! See this photo: http://www.bittybirds.com/cadie-kitchen-baseboard.jpg You can use a similar baseboard to make a Wooden chassis! Do you undestand me? Best Regards, Felipe
#6 |
So you are saying that you can use a bird to make the chasis?????
Chris |
#7 |
Chris.
Please not forgot the bird! See the wooden baseboard! With this you can make a wooden base to your pre or amplifier.
#8 |
In this site: http://www.eliaswoodwork.com/casing7.htm you can see many perfils of baseboard.
This perfil is good! http://www.eliaswoodwork.com/images/molding/j335.gif This perfils is seeling in meters! THE PERFIL WHO I USE ON MINE PRE is http://www.eliaswoodwork.com/images/molding/j602.gif . This is the simplest. But the pre-amp looks good! I haven't a photo. Best Regards
#9 |
I'm not sure if they can work from a pre-existing enclosure, but try emachineshop.com. They have a really good free CAD program that I have used to design a yet to be made chassis. Not cheap by any means, though.
#10 |
| Any suggestions on setting up a dedicated electronics work area at home ? | Ohighway | Equipment & Tools | 24 | 16th September 2008 11:41 PM |
| Put amp in chassis, then, right channel doesn't work! | ambience exists | Tubes / Valves | 11 | 4th August 2008 10:30 PM |
| What d'you put in the PSU chassis, and what in the circuit chassis? | andyjevans | Tubes / Valves | 5 | 14th December 2007 11:41 PM |
| How to star ground to Chassis without a Chassis?? | Minion | Chip Amps | 10 | 5th November 2006 04:28 PM |
| Where to get chassis or chassis parts in Vancouver? | Prune | Parts | 1 | 7th July 2004 05:37 PM |
| Page generated in 0.11122 seconds (77.41% PHP - 22.59% MySQL) with 11 queries |
