diyAudio Sponsor
Old 27th June 2006, 04:36 AM   #1
martioz is offline martioz  Australia
Default Please help ID this rectifier:
Please help to ID this russian rectifier tube:
Old 27th June 2006, 05:26 AM   #2
poobah is offline poobah  United States
poobah's Avatar
Godzilla? King Kong? Mongo?
Old 27th June 2006, 07:06 AM   #3
Miles Prower's Avatar
Are you certain that it's a rectifier? It looks like a sodium vapor arc lamp.
There are no foxes in atheistholes
www.dolphin-hsl.com
Old 27th June 2006, 02:15 PM   #4
tubelab.com's Avatar
Back in the days before silicon rectifiers the only choices were selenium for relatively low current, and a device known as a "Tungar Bulb". That is a large high current low voltage rectifier tube. Most of them used Mercury or Argon to lower the voltage drop. They were used in large battery chargers.
Google "Tungar bulb" or "Tungar Rectifier" Some were made by the Tung Sol corporation.
Too much power is almost enough! Turn it up till it explodes - then back up just a little.
Old 27th June 2006, 04:31 PM   #5
kevinkr's Avatar
It doesn't appear to be an x-ray tube, it does appear to be some sort of high voltage rectifier. I have seen similar rectifier tubes in 1920's vintage radio transmitters, unfortunately I am not really familiar with these and can't identify this one.
www.kta-hifi.net
Bridge rectifier vs Full wave rectifier hilbert_mostert Tubes / Valves 4 28th April 2009 08:26 PM
6CJ3 rectifier or 6D22S rectifier 56oval Tubes / Valves 10 19th April 2007 09:48 AM
81 Rectifier Diy martin Tubes / Valves 4 14th January 2006 01:54 PM
Anybody heard about Tarzian Silicon Rectifier for Tube Rectifier Replacement? zxx123 Tubes / Valves 4 21st February 2005 04:02 AM
Integrated Rectifier Bridge VS Rectifier Diodes Sci Chip Amps 11 16th July 2004 02:43 PM
Page generated in 0.09616 seconds (73.62% PHP - 26.38% MySQL) with 11 queries
