| diyAudio Sponsor | ||
What impedans should the trafo be for triodmode.Is 2,5k to low?
Regards Åke |
#2 |
2,5k is a bit high, I used something like 1,3k in my prototype PL504 SE triode amp.
#3 |
Ok,hello "Fuling"
Regards Åke |
#4 |
It will probably work just fine, as long as the transformer can handle ~100mA DC. EL504 seems to work best at low voltage and high current.
#5 |
I have 2 tubes by the number of"76" can these be used as a driver for the El504,if I use the 504 at 80mA 175v.The 76 have a ampl.faktor of 13.8, does that mean that if i send 2v in I get 27,6 out?If its to low I ment to use a 6DJ8
Regards Åke |
#6 |
What driver did you use?Any feedback? Do you have a schema?
Regards Åke |
#7 |
If I remember correctly I used PC86 as drivers, loaded with Hammond 156C chokes. The OPT´s was my own design that involved 25% cathode feedback.
The amp put out a couple of watts and sounded quite darn good, but for various reasons it never got further that the prototype stage. No schematic available. |
#8 |
This is my PL504 push-pull amplifier.
I have good results with 750 Ohms Plate to Plate. http://edonion.com/documents/EdonionSpeedy.pdf You can see it here Transformadores I hope you enjoy it. Sounds very good |
| Currently Active Users Viewing This Thread: 2 (0 members and 2 guests) | |
| EL504/PL504 spice model | aparatusonitus | Tubes / Valves | 7 | 29th January 2009 09:15 PM |
| Power supply options.. bigger trafo with less caps or medium trafo with heavy caps? | rhythmdiy | Chip Amps | 9 | 23rd October 2007 12:30 AM |
| trafo.. | samsagaz | Chip Amps | 16 | 31st August 2004 02:17 PM |
| FS: 22 pcs NOS NIB RSD EL504. | webercarbmann | Swap Meet | 0 | 25th July 2003 02:03 PM |
| Trade EL504 - ? | webercarbmann | Swap Meet | 0 | 23rd June 2003 11:07 PM |
| Page generated in 0.08630 seconds (81.93% PHP - 18.07% MySQL) with 10 queries |
