| diyAudio Sponsor | ||
here's the datasheet: http://www.mif.pg.gda.pl/homepages/f...129/g/GZ33.pdf
I wonder if it's the same as the Rs (surge limiting resistor) in the Bendix 5839 datasheet (see the schematic on page 2 : http://www.mif.pg.gda.pl/homepages/f...131/5/5839.pdf). Also is it needed? thank you for the replies. |
#2 |
This is the resistance that must be provided to limit peak current if the maximum input capacitor is used. You don't need to add a resistor if the effective series resistance of the transformer (secondary plus reflected primary resistance) is high enough. PSU designer will calculate this value if you fill in voltage, primary and secondary resistance.
What REALLY matters is staying within the peak current rating of the tube. If you have a high enough transformer resistance, you can use 470 uF capacitors and the rectifier tube won't care. Conversely, if you have a very low transformer resistance, you may need to use less input capacitance to avoid overstresing the cathode. Exceeding the peak repetitive current rating is likely to cause arc-over. PSU Designer will show the peak current for you. |
| 6G-A4 anyone have a datasheet? | jp74 | Tubes / Valves | 5 | 23rd June 2009 05:28 AM |
| GZ33 Rectifier drop? | Psychobiker | Tubes / Valves | 2 | 16th February 2008 08:25 PM |
| Datasheet help | Stocker | Parts | 0 | 10th March 2004 01:36 PM |
| Datasheet | Piersma | Digital Source | 3 | 29th January 2003 07:49 PM |
| Page generated in 0.07086 seconds (66.09% PHP - 33.91% MySQL) with 10 queries |
