diyAudio Sponsor
Old 22nd June 2006, 04:09 PM   #1
Default Adding Subwoofer output to Aikido preamp circuit
I would like to add a summed L/R subwoofer out to my Aikido preamp circuit. I already have an active crossover (60 Hz) and sub dedicated amplifier, so I'm looking for a summed line out circuit.
Any ideas on the implementation of such.
Thanks, dr_sleep
Old 22nd June 2006, 04:40 PM   #2
Giaime is offline Giaime  Italy
Giaime's Avatar
Send a message via MSN to Giaime
Maybe it's too simple, but you should be able to do the mixing with 2 resistors, one from L output, one from R output and connected togheter.
Old 22nd June 2006, 04:45 PM   #3
I've summed the active crossover L/R outs via 2-100 ohm resistors to a mono SS amp, I could do the same for a mono pre out in the preamplifier.
dr._sleep
Old 22nd June 2006, 07:08 PM   #4
agent.5 is offline agent.5  United States
tubecad has one or two blogs about using two coupling capacitors in an aikido for two outputs. Using different capacitor values, you can not only get 2 outputs, but different frequency for high pass filters.
Old 23rd June 2006, 12:10 AM   #5
Thanks for the input.
I decided to use the stereo 400 ohm transformerless outputs of the Aikido (33uF Solen coupling cap) to my active crossover which then sums to mono before going to my mono sub amp (Crown DC 150 strapped) and a Decware 10 inch Deathbox (http://www.decware.com/newsite/mainmenu.htm),
sounds nice and low with mucho puncho.
dr_sleep
Old 13th November 2007, 04:18 PM   #6
Nice work Dr.
Any change you could make a drawing of your schematic ?
I'm planing to make a headphone/preamp comby my self and would love some inspiration
Adding Subwoofer output to Sonic T-Amp HolyGhostFire20 Class D 4 23rd November 2011 07:33 PM
Adding Subwoofer to FE206's yan6 Subwoofers 2 27th January 2009 12:59 AM
Aikido circuit question jayme Tubes / Valves 3 14th September 2007 09:31 PM
Adding secondary of output transformer into cathodes of output stage ? Eico ST-70 freddymac406 Tubes / Valves 3 21st April 2007 06:15 PM
Adding Vol Port to this LM3886 Circuit! FREQUENCY Chip Amps 12 12th March 2005 09:08 AM
Page generated in 0.07947 seconds (72.05% PHP - 27.95% MySQL) with 10 queries
