PS for GG - look for better channel separation
Old 26th June 2006, 01:13 AM   #11
arnoldc is offline arnoldc  Philippines
Send a message via Yahoo to arnoldc
go ultimate- use dual mono power supply.
Old 26th June 2006, 05:23 AM   #12
senderj is offline senderj  Hong Kong
ackcheng,
Have you build your shunt reg? If so, what is your comment? Any kit available for the shunt reg?
Old 28th June 2006, 01:56 AM   #13
ackcheng is offline ackcheng  Hong Kong
Send a message via ICQ to ackcheng
Currently building one. Have not tested yet. But the topology seems good. You can download the manuel here
http://www.euronet.nl/~aespreng/Shuntregv11d/Manual.pdf
If you are in HK, you can also contact me by email!
Old 28th June 2006, 12:25 PM   #14
On Hiatus
SY's Avatar
You can decouple very simply by adding a resistor in series with the feed to each of the caps you split out. Figure that if you size the resistor to drop 5-10V (use Ohm's Law), you'll isolate the channels pretty well.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
PS for GG - look for better channel separationHide this!Advertise here!
Ground domain separation borges Power Supplies 1 6th February 2008 09:40 PM
A/D Ground plane separation and common supplies rtarbell Parts 1 16th August 2006 04:05 AM
LED infrared signal separation rtarbell Digital Source 2 11th July 2006 02:17 PM
How important is channel separation in amp design? Commited Class D 9 9th February 2005 11:14 AM
Fisher Stereo Separation question. Thatch_Ear Tubes / Valves 1 29th May 2002 07:02 AM
Copyright ©1999-2017 diyAudio
