diyAudio Sponsor
Old 20th June 2006, 04:07 AM   #1
nuvo is offline nuvo  United States
Default Conn organ conversion to amp
Schematic needed for a Conn UA 6026 organ chassis - do not have any other information on this unit, but I just could not pass it up - it has tube positions for 4/7027A, 2/7868, 2/7199, and 2/12AX7 - just the 7199 & 12AX7 are missing. Everything else appears (cosmetically) good.
I did not get a chance to look under the hood, but I think it has potential as an audio amp or guitar amp. Does anyone have any information on converting an organ amplifier to audio or guitar use?
Thanks for any help.
nuvo
Old 30th September 2010, 09:51 PM   #2
I'm working (having a pro do it) on a conversion of a 6026 Conn right now. The amp is a stereo 20/20w rms. a mono preamp will be directed to one side. the 3-way standby will be A+B - Standby - A. Amp B will default from the Pre unless a second pre is pluged in. Each amp will have its own output. More info as project progresses.
Old 15th October 2010, 02:53 AM   #3
I have one of these too and am looking for a schematic. I am hoping to use this as a stereo amp with subwoofer on the third channel. This will make a nice Hi-Fi amp. Very quality build with nice iron on it.
Old 15th October 2010, 05:25 AM   #4
I doubt the unit is so complex you can't reverse engineer it. I have traced many a schematic diagram; it just takes patience. On top of that, you probably can draw most of it without looking anyway. Four 6L6s either push pull parallel or push pull two channels (probably the latter). Solid state rectifier. The only hard part would be the bias circuit and the tone controls, if any.
Old 29th November 2010, 01:59 AM   #5
Default Conn Organ 6026 to Guitar amp. Done
Well, the conversion of the Conn 6026 Organ amp to Guitar amp is complete. I like it alot!! If anyone has a 6026 they want to sell let me know. I would love to have a second as a backup amp. here are a couple pics.
Old 29th November 2010, 06:32 PM   #6
chops is offline chops  United States
chops's Avatar
I've got an old Baldwin amp that I believe used to be a 100 watt mono amp from some recent research I did on the web. It was converted over to stereo operation a few years ago and I finally got it back up and running a month or so ago. It's now rated around 23 watts per channel and sounds great! And just like the Conn amps, the Baldwin has some massive quality iron.
Old 12th March 2011, 10:01 PM   #7
I've got a Conn 6050 amplifier (tubes/valves included) that I'm attempting to get to work as a guitar amp head. It is missing all external connectors (Power 1 & 2, Internal & External Speaker, and Expression Control). I need a source for a schematic for this amp + all external wiring so I can get this working. Any ideas where I could find such a beast?
Old 25th July 2011, 12:39 PM   #8
Default Conn 6026 w/ cathode follower preamp
I have a schematic for the Conn 6026 Chassis (modified) email me for a copy an notes. me@markeckard.com
Seeking schematic for Conn organ amp Captn Dave Tubes / Valves 1 7th May 2010 12:59 AM
Help me out with my organ to guitar amp conversion, please. David E H Instruments and Amps 3 24th February 2009 07:47 PM
Conn Caprice organ ThSpeakerDude88 Tubes / Valves 26 7th October 2007 04:33 AM
Parallel-Push-Pull KT66 organ amp conversion ??? jon_010101 Tubes / Valves 3 2nd June 2006 01:53 AM
conn organ amp help jazzgene Instruments and Amps 0 11th April 2006 05:51 PM
Page generated in 0.09735 seconds (78.13% PHP - 21.87% MySQL) with 11 queries
