| diyAudio Sponsor | ||
Hey all,
I have been working on my latest project, and right off the bat Ihave hit a snag. I am using a Hammond 183K12 to power the heaters of 2 6AS7G and 2 6SN7. I Connetect the transformer as follows: (the bottom transformer is my Hammond 269AX for the PSU section) ![]() When I turned on the power, the transformer started smoking, and I quickly cut power. I disconnected everything from the secondaries, and turned it back on to test the voltage, and unfortunately I got zero. I have ordered another transformer, but I'd like to knwo what I did wrong. I am about 99.9% sure I wired it as shown by my drawing. Any ideas? Thanks in advance. |
#2 |
Banned
What is the brand what does it look like ? Maybe you can request a drawing diagram to connect it to the ac voltages you need.. I have seen some people buy a 110V ac tranny and use 220 buy mistake. We can help you if you can provide details of make model etc etc |
#3 | |
Hi jleaman,
Your diagram is okay. How fast did you say it smoked? I assume you did check the heater currents against the Hammond's ratings. I haven't yet. You always leave some headroom there. But even still, I've not seen a transformer smoke quickly unless it's high current and the winding is shorted. The hum would tip you off first I'd think. -Chris |
#4 |
i have been doin' this for 40+ years and have never made a trannie smoke -- even through the thick and thin of many catastrophes in audio, ham radio and physics labs which destroyed several transformers (I burned out the transformer in my Eico 753 Tri-Band transceiver when I keyed down on 20 meters for too long -- rewound the transformer !)
#5 |
If you accidentally wire the two parallelled primaries so they are out of phase, the transformer will smoke immediately! Don't ask me how I know this. If the power wasn't on long, there may still be some life left in it. I woudn't use it in an amp, but I would try again before you smoke the new one.
If you look at the diagram on Hammonds web page you will see a small dot next to one of the pins on each winding. Whenever two windings are connected in parallel the pins with the dots are connected to each other, and the pins without the dots are connected to each other. For this transformer, connect pins 1 and 4 together. Connect 3 and 6 together. Connect power to the 1-4 pair and to the 3-6 power. Test for voltage with no load. If you have voltage, then try it with a load.
Too much power is almost enough! Turn it up till it explodes - then back up just a little. |
#6 | |
Banned
Id also try it with a variac too. Power it up slowly |
#7 | ||
#8 | |
The dots are also present on some vintage potted HP transformers... Thanks, James |
#10 | |
| Have a smoking 60-0-60V transformer and looking for a project. | Shoog | Solid State | 11 | 16th April 2012 09:30 PM |
| Odd transformer with 6X4 tube mounted on top.. smoking more than my uncle Frank | freqazoidiac | Tubes / Valves | 1 | 26th September 2008 10:52 AM |
| Zen V4 Smoking Q5 | Diomedian | Pass Labs | 6 | 15th November 2005 02:46 PM |
| Smoking Amp | jkramer | Solid State | 15 | 28th August 2004 04:17 PM |
| DOZ smoking? | Kari | Solid State | 8 | 1st February 2004 02:40 PM |
| Page generated in 0.10767 seconds (88.66% PHP - 11.34% MySQL) with 10 queries |
