diyAudio Sponsor
Old 19th June 2006, 11:04 AM   #1
Send a message via MSN to firefart_1st
Talking dumb question :P KT88...
i need to clear one thingy :P
on a push pull amp with 4 KT88
the output transformer will be 2.25Kohm pp ? right ?
after a repply i'll tell why i'm asking this...
music music music music
Old 19th June 2006, 11:11 AM   #2
lndm is offline lndm  Australia
According to the data sheets, this might be ideal if you are using fixed bias on a tetrode or ultra-linear configuration, with a 560V B+.
Old 19th June 2006, 11:16 AM   #3
it's an 560V supply.
and its and weird amp that was not working right and and friend of mine sent it to me.
the output transformer is near 8K pp
thats why i asked...
like that the amp has low power and distorts when puted loud.
fixed bias it is too.
i think its an hiwatt like power amp. and the preamp is somewere and vox or an fender...
its a total custom amp :P but not done right
Old 19th June 2006, 11:57 AM   #4
So watcha gonna do with it?
Old 19th June 2006, 01:56 PM   #5
i'm gonna change the OT to an 2.25K with 2 4 8 and 16 Ohm output ...
i have a local man to make that
then ill test it up.
the owner said that like the tone of that amp and wants it to work the best.
i said to him if we want connect a 4 ohm speaker on tha 8 ohm out or even on the 16 ohm output. i dont guaranti itts good but. until the OT is made and paid :P o wont mess with that amp.
its an 200W monster !
bass or (clean) guitar
i was feeling dumb about that OT...
a tough i was wrong when reading that datasheets
Old 19th June 2006, 02:10 PM   #6
I used to run PP 6550's at around 100Wpc. I did some good listening with that amp. I have read about 250W from PP KT88's. It was described as sounding effortless, like there was unlimited power.
Old 19th June 2006, 02:34 PM   #7
'unlimited power' sounds good to my ears.
but no so good for my speakers
Dumb question, but... johnm Tubes / Valves 3 13th June 2008 10:14 PM
Dumb question. G Tubes / Valves 2 16th January 2008 08:16 PM
maybe this is too dumb a question... dannyspencer Solid State 6 18th April 2004 04:57 PM
Thi is probably a dumb question.... Konnan101 Multi-Way 4 11th January 2004 01:40 PM
Dumb Zen V4 Question Panelhead Pass Labs 4 26th April 2003 04:15 PM
Page generated in 0.07980 seconds (73.48% PHP - 26.52% MySQL) with 10 queries
