| Home | Forums | Articles | Gallery | Blogs | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
| Tubes / Valves All about our sweet vacuum tubes :) |
Thread Tools |
After gaining some confidence in building some low voltage solid state power supplies for CD players thought I’d tackling a valve regulated power supply for a preamp.
I have gleaned much information from the posts here and have adapted part of Frank’s 250V regulated power supply using a CLCLC filter prior to regulation. However, since this is my first DIY adventure into building valve stuff I thought I’d get some feedback and advice before I actually build the circuit attached. I was going to use this power supply for an Aikido preamp (current draw approx 30mA/channel) build would also like the versatility of using it for other circuits, maybe an Ultrapath. Transformers and chokes have been salvaged and capacitors are MKP motor run. I will be using a 5W4G valve rectifier which seems similar to the 5Y3G on paper. Using Power supply Designer II, I’ve used C1 (0.47uF) to set the voltage to 300V prior to the regulator. My major questions are: By splitting the voltage into R & L channels after C2, would the added capacitance of C3a & C3b and C4 on each channel overload the rectifier ? Although I’ve used a small input cap will it still function similar to a choke input (constant current) power supply? It all seems overkill (but I’m using salvaged parts), would there be a loss in performance by simplifying it by something like: 270V – 0 -270V -> 5W4G -> 10uF -> 7H (88ohms) -> 100uF -> 7H (88ohms) -> 100uF, then split into R & L each with the regulator? Any feedback and advice appreciated. Cheers Richard
"A little learning is a dangerous thing" |
#2 | |||
#3 | |
Hi Indm
Thank you very much for the feedback. If I could trouble you some more Quote:
I have modelled using a larger cap and a RC filter to reduce B+. However, PSD II indicates that "the IFRM (current forward rectifier maximum) of 0.38A has been exceeded" when anything greater than 2uF after the rectifier is used. Using a 270V - 0 - 270v transformer and C1 of 20uF C2 = C3 =80uF gives me the voltage I need b4 the regulator and does not exceed the IRFM, but any increase in capacitance does. And I planned to put at leat 80uf after the reg. How could I address this issue of IRFM, while using the 5W4G rectifier? Cheers Rich
#4 |
OK, some points.
The spec sheet specifies a max of 4uF for capacitor input. This is a directly heated device, there is therefore no controlled warmup to hold the B+ off the other devices before they are warm. You could implement this some other way if you wanted to. Have you considered any other rectifiers? Chokes in the power supply can account for ringing. When designed well, chokes in a power supply are a good thing. If not, and even if they don't cause a ringing problem, they can cause spikes that exceed rectifier limits at turnon. If you are designing an amp with a relatively non constant current draw, such as with a class AB output stage, you would want a minimum of series resistances in the supply as these will drop a varying voltage with the varying current. Similarly, using a borderline small input cap may produce a rectified voltage that is too dependent on current draw. I'm not sure I understand when you said that 2uF was too much, then said that you tried 20uF and it was good. Could you put it another way perhaps? I wonder whether you might find this interesting http://www.siteswithstyle.com/VoltSe...C_ringing.html it is a little about what is going on between your rectifier and regulator. |
#5 | |||
Hi Indm & others,
Thanks for feedback and the link, I did find it very useful. Quote:
The fast turn on will only effect the ECL85 in the regulator as the signal valve heaters will be supplied by a separate XF and PSU. In regard to the link of PS ringing, a few points gathered from the website: “As expected with large resistances, the damping is good, but the regulation is poor” “The first capacitor after the rectifiers affects both damping and regulation. Bigger is not necessary better in this location”. “Low DCR in the inductor is good, but it can be over done. If you buy a low DCR inductor, lower the Zo of the LC tank by buying a larger capacitor for C out.” Quote:
The aikido preamp it will be powering will be running 5-6mA per triode so 20-30mA per channel (total of approx 50 + 10mA) Quote:
I have remodelled the PS b4 the rectifier using a 270-0-270 V transformer and a 3uF input cap. This time I have used a low DCR inductor (67 ohms). I didn’t find any differences in PSD II by increasing the inductors DCR to 167 ohms (by adding R in series), so left it at 67ohms. In light of this I have increased C2 (C out) to 100uF. All in all the PS gives me about 270V prior to the regulator depending on current draw. By changing to a 5V4 and leaving C1 at 3uF, voltage increases to approx 290V, but seems to show a very little ringing. Replacing the 12H 67 ohm inductor with the 19H 234ohm one does cure the ringing so to does adding 200ohm series resistance to the 12H ie making 267ohms. I will try and put together the PS this weekend, but until then any comments & suggestions are most welcome. Cheers Richard
#6 | |
#7 |
Hi Miles
Many thanks for the feedback. It’s an excellent idea of using solid state. There is a nice example of a regulated solid state power supply for preamps in Morgan Jones Valve amplifiers 3rd edition. As a novice I was considering building that, but I wanted to learn about valve PSU and just love the look of “glowey bottles” on a cold night. After some more modelling I finally seem to have a better understand of the link Indm posted regarding ringing. I tried the following (Please forgive the repetition): The 5Y3 was modelled instead of 5W4 270-0-270 -->5W4 -->3uF-->12H 67ohms--> 120uF --> 7H 88ohms --> 80uF changing the rectifier to 5V4 and increase the input cap to 6uF, to get more B+ 270-0-270 -->5V4 -->6uF-->12H 67ohms--> 120uF --> 7H 88ohms --> 80uF Both designs above exhibit a little ringing increasing the series resistance of the chokes (by adding a resistor immediately before the choke) yields a smoother V out curve, thereby curing ringing. Ie 270-0-270 -->5V4 -->6uF-->12H 167ohms--> 120uF --> 7H 188ohms --> 80uF Forgive my ignorance, but can anyone comment on increasing a chokes DCR by just adding a resistor in series, is it allowable ? Richard
#8 | |
#9 |
Hi Indm,
since I don't have a datasheet, is the max capacitance for the 5W4 in cap input 4uf? thanks! |
#10 |
Is this what you're looking for? http://www.mif.pg.gda.pl/homepages/f.../049/5/5W4.pdf
| Thread Tools | |
| DC Power supply questions, advice appreciated! | gypsielectro | Power Supplies | 2 | 1st April 2009 11:39 PM |
| Need Power supply advice for Andreas 845 | Rob11966 | Tubes / Valves | 7 | 12th November 2008 03:22 AM |
| need power supply advice for future power amp project. | boricuaso | Chip Amps | 13 | 6th February 2008 02:24 PM |
| need advice on aleph 3 power supply | jeapel | Pass Labs | 7 | 3rd September 2005 12:02 PM |
| Page generated in 0.14520407 seconds (86.51% PHP - 13.49% MySQL) with 11 queries |
