CLC vs LCLC: is there any advantages other... CLC vs LCLC: is there any advantages other... - diyAudio
Old 17th June 2006, 11:09 AM   #1
jarthel is offline jarthel  Australia
Default CLC vs LCLC: is there any advantages other...
having a lower voltage across the 1st cap on LCLC and other differences as mentioned in the rectifier datasheet?
here's what i'm thinking
lclc:
xformer -> 5V4G/5U4GB -> 10H 200mA 87ohm-> 10uF -> 10H 200mA -87ohm > 100uF
clc:
xformer -> 5V4G/5U4GB -> 10uF -> 10H 200mA 87ohm -> 100uF
the B+ after the 100uF will be regulated using a design found in the RCA designer's handbook (chap 33 fig 33.14).
thank you for the help
Old 17th June 2006, 01:15 PM   #2
Eli Duttman is offline Eli Duttman  United States
When a choke I/P filter (LCLC) is used, additional regulation circuitry is usually not needed. The O/P voltage of a choke I/P filter is quite stable, even as the draw varies.
Have you studied the theory of choke I/P filters? If not, READ. Don't forget to ensure that the critical current gets drawn. In the case of a 10 H. 1st inductor, place a high wattage rated 10 KOhm bleeder resistor across the 1st filter cap.
Eli D.
Old 17th June 2006, 01:19 PM   #3
can you suggest what article to read?
also, someone from AA suggested a 220K-330K on the last cap. is he wrong? maybe it's applicable to clc only?
thanks for the reply.
Old 17th June 2006, 01:37 PM   #4
NEETS (US Navy) stuff here.
NEETS has all sorts of basic electronics info.
Eli D.
Old 17th June 2006, 02:10 PM   #5
iggy80fr is offline iggy80fr  France
Check Duncap Amps Power Supply Designer II.
Very helpful !
J.P.
CLC vs LCLC: is there any advantages other...Hide this!Advertise here!
Advantages of off-set Tweeter vdi_nenna Multi-Way 4 5th May 2007 02:40 PM
Series and parallel...any advantages jonz Subwoofers 6 24th January 2007 09:21 PM
Advantages of stereo sub? rs1026 Subwoofers 23 6th December 2004 04:46 AM
Active cross over - any advantages? Salinas Multi-Way 45 16th March 2004 03:58 AM
Advantages of Cascode? RichardJones Solid State 2 18th March 2003 05:50 PM
Copyright ©1999-2017 diyAudio
