diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Tubes / Valves (http://www.diyaudio.com/forums/tubes-valves/)
-   -   Velleman K4040 conversion from EL34's to KT88's (http://www.diyaudio.com/forums/tubes-valves/81587-velleman-k4040-conversion-el34s-kt88s.html)
GeorgeK 16th June 2006 10:45 AM
Has anyone converted a Velleman K4040 from the STD EL34 output tubes to KT88's?
Tubes4e4 17th June 2006 07:50 AM
Re: Velleman K4040 conversion from EL34's to KT88's
Yes, try this link., scroll down a bit.
If the link doesn´t work, use the cached google version instead.
Tom
assimaki 28th June 2008 11:29 AM
Hallo!
The link is not working and no google cached is available.
Do you know where can I find info about the KT88 conversion?
Svein_B 28th June 2008 01:20 PM
Try www.archive.org
Here is the 4040 article: http://web.archive.org/web/200512101...com/k4040.html
SveinB.
assimaki 28th June 2008 03:50 PM
Thanks!
dagney2000 2nd July 2008 09:41 AM
How is the project going?
Any review on your improved Tube amp?
I have 2 Velleman kits, and want to this project aswell.
assimaki 8th February 2009 07:12 PM
It was a long project as after the proposed mods and the use of 6550 the results were not OK.
It seems that the concertina design can not drive the 6550/KT88.
I returned back to original design.
The sound of K4000 was always average, it was improved only when i used a TFK ECC82.
In a Greek forum (avsite) they suggest to change from 1 ECC82 and 2 ECC83 to 1 ECC83 and 2 ECC82.
Resources saved on this page: MySQL 18.75%
