diyAudio Sponsor
Old 15th June 2006, 01:53 PM   #1
gianis is offline gianis  Greece
Default px25
I found 4 tubes PX25 [VR40] NOS Osram Marconi brand, any proposal of designing something around these tubes?
Old 15th June 2006, 03:25 PM   #2
EC8010 is offline EC8010  United Kingdom
EC8010's Avatar
You could make a glorious PP 15W amplifier with those. Mind you, as you'd probably never be able to afford to replace the output valves when they failed, I expect you'd prefer to send them them to me for proper disposal. I'd even refund the postage!
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 15th June 2006, 03:59 PM   #3
Default px25
Please any data for px25 tube?? thanks,
Old 15th June 2006, 04:16 PM   #4
croat47 is offline croat47  United States
croat47's Avatar
Here's one source:
http://www3.osk.3web.ne.jp/~euvalve/data/px25.html
And another:
http://www.ginko.de/user/franz.hambe...xrefp.html#TOC
Google = good.
Old 15th June 2006, 04:46 PM   #5
Default px25
Ok thanks again ..gianis
Old 15th June 2006, 04:49 PM   #6
EC8010's Avatar
Here's the mother and father of all valve data sites:
http://www.tubedata.info/
It has the Osram PX25 data sheet. Note that PX25 requires a British 4-pin base.
Old 15th June 2006, 05:05 PM   #7
kevinkr's Avatar
Both KR Enterprises and TJ make the PX25 in the original British 4 pin base and UX-4 U.S. style base with 4V/2A filaments.
Note that TJ also makes the PX25 in a UX-4 base with a 5V/1.6A filament for those wanting to sub it in an existing amp with say 300B.
Some other changes may be required depending on amplifier design.
So - there shouldn't be a problem getting good quality replacements for worn out PX25 for the forseeable future. (I would get some new ones fairly quickly and use the classics for critical listening.)
I would do an SE amplifier and keep the other pair as spares if it were me.
Plenty of Japanese designs out there using this tube incidentally, many of which will be found on otherwise incomprehensible Japanese language websites.
www.kta-hifi.net
PX25 DRD Power amp. Steve Cresswell Tubes / Valves 53 6th September 2008 04:23 PM
Px25 gianis Swap Meet 3 25th June 2006 02:27 PM
PX25 SE without NFB jamesjung21 Tubes / Valves 2 12th January 2006 03:33 AM
SE PX4 or PX25 amp, anyone built one???????? powertriode Tubes / Valves 6 15th December 2004 05:39 AM
Any DHT PX25 DIY user here??? siu sin man tho Tubes / Valves 0 12th February 2004 05:32 PM
Page generated in 0.08721 seconds (76.62% PHP - 23.38% MySQL) with 11 queries
