| diyAudio Sponsor | ||
I changed 300b tubes with new ones after the tube amp was unplugged from the wall for a while, and smoke started coming out from the tubes,then I turned it off and unplugged it, I made sure all the tubes were plugged in the socket before turning it on. Then I tried it again and hear a very strange noise coming from the amp. So I took them out and then I noticed brown burn marks at the top of the tubes. I put the original ones back in and they didn't burn but I heard the strange noise coming from the tube amp so I shut it off immediately. What should I do? Is this could be caused by a bad tube socket, or just a bad solder point.. anything else that could cause this problem?
thanks |
#2 |
what kind of noise was it? was it a low hum? are you using AC, or DC heaters?
#3 |
Some new production 4-pin sockets have holes that are large enough to plug a tube in the wrong way. Could that have happened?
#4 |
my first thought too ,kyle, i hate to say it, i've done this! when i saw the current meter instantly slam over to max rather than the slowish climb up , i shut it down! the tube plays to this day-good advertising for jj!
#5 |
Judged by ectobia´s description I think that the tubes were possibly bad, plugged the wrong way around or whatever. This caused a short somewhere in the circuit - which still exists - and now the high current in the mains transformer "resonates" its windings, thus the "strange sound from the amp".
| tube amp subwoofer hum problem | timolien | Tubes / Valves | 3 | 13th September 2006 01:41 PM |
| Problem with tube overheating. PLEASE HELP | NotInTheMafia | Tubes / Valves | 0 | 4th December 2004 04:41 PM |
| Tube preamp problem | @mot | Tubes / Valves | 20 | 23rd September 2004 07:50 PM |
| Page generated in 0.08535 seconds (71.86% PHP - 28.14% MySQL) with 10 queries |
