| diyAudio Sponsor | ||
#61 |
SY, i'd like to ask fews newbie's questions :
1. Do I really two power supply? Can We just buil one power supply ? Does that will have any effect? 2. If we have to use 2 power supply, the what is the transformer's capacity for the driver? i have one small transformer (270VAC/20 or 35mA without CT). can I use that? 3. Could you explain me why you use regulated B+ for screen grid while you use simple CLC supply for Driver? Because i usually build amps with regulated at driver (even I use DC for heaters) and use standard CLC for Output? Thanks Ferry
Mas Penk |
#62 |
Ok, sy!
Can I use the AN TRANS-200 (8k 15w)? How do I adapt the circuit to this? And not least what spec's do I need for the mains transformer? If I go for this design, it will be my first tube amplifier from scratch! I need a design that will give me some good sound in my rf-3's to inspire to continue diy'ing. |
#63 |
diyAudio Editor
Arnoldc's idea is a good and simple one. Even with a conventional chassis, it could have feet say 1 cm tall and the LED's mounted on the bottom in a simple grid on a panel. Then the chassis would "hover" on a pool of red light, like the automobile guys do to their cars. The "look of power"
#64 |
SY,
Do you have any more information about this amp? What I would like to know is Zo, distortion pattern and more technically things than just the pattern of the red light district LESs. I can see that you have put in some large grid stoppers that will help in case of blocking and that the forward roll off frequency is quite low (indicates bad OPTs?). Any comments?
Life is hard - Then you die. |
#65 | |
With pentode output stages, the screen supply is MUCH more critical than the plate supply. So regulation is called for. As a benefit, it gives a very convenient way to adjust idle current. With the driver supply separated and the driver running class A, regulation doesn't bring much to the table.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#66 |
EsE, I don't know that transformer. Is it made for push-pull? If so, it should work.
Jan, there will be much more info in the actual article. Bug Bas about publication date. BTW, good pickup on the seemingly odd value for grid stoppers!
#67 | |
diyAudio Moderator Emeritus
#68 |
SY, I have one question about the Maida regulator. I read (probably Morgan Jones) that the current through the zener diode should be at least 5mA for it to operate without producing to much noise. If my math from after 2 in the morning is right, in your design there is about 1,3mA going through the zener. Is that sufficient? Did you try higher currents? What where the results?
Many thanks Erik |
#69 |
The noise from the zener isn't critical in that position, being knocked down by the regulator and feeding a stage that's at 300V.
BTW, I should mention that the amp has less than -100dB noise referred to max output.
#70 |
Hi SY Thanks for the reply. Erik
| Red Light District/Baby Huey (EL84 P-P) Output Iron | dsavitsk | Tubes / Valves | 3 | 14th February 2009 01:21 AM |
| Red Light District Amp Screen Reg | mach1 | Tubes / Valves | 20 | 28th February 2007 09:37 PM |
| Rogers Cadet III to SY's Red Light District or Gingertubes's Baby Huey | jkeny | Tubes / Valves | 24 | 22nd January 2007 09:28 PM |
| Page generated in 0.13276 seconds (86.76% PHP - 13.24% MySQL) with 11 queries |
