diyAudio Sponsor
Old 21st November 2009, 02:32 PM   #601
SY's Avatar
Ahh, I see what you guys are getting at. Yes, once the conventional RC cathode bias has been removed, and the grid current limited, you can then build a negative supply, regulate it, then attach the bottom of the grid leaks to it. Or, for five bucks and a free light show, you can get the same instantaneous bias voltage recovery and no more impedance penalty than the usual idle current sensing resistor.
"...we stumble and get up, we are sad, confident, insecure, feel loneliness and joy and love. There is nothing more; but I want nothing more.” - Christopher Hitchens 1949-2011
Old 21st November 2009, 02:51 PM   #602
jackinnj's Avatar
Originally Posted by GK View Post
Won't work. An LM317 has a single NPN series pass element, so, as a voltage regulator, it can only source current, not sink it. In other words, the cathode current of the tube will reverse bias the pass device and the voltage will shoot up to whatever.
It is fine to use an LM317 here as a current regulator/sink as it will need to be bypassed with big electro anyway. This makes the HF performance of the current regulator/sink irrelevant.
But anyway, all this still looks quite pointless to me. I'd just connect the cathodes to ground and use (adjustable) fixed bias on the grids.
Further to your point -- Walt Jung's 2 part series on current sources is available on the AudioXpress website for free. Well worth the reading.
Old 23rd November 2009, 12:33 AM   #603
TheGimp is offline TheGimp  United States
TheGimp's Avatar
Yup, I wasn't thinking. LM 317 is a source not a sink.
I have both output tubes biased up with the LED stacks now. I trimmed the screen supply resistor to get it to 200V and all is up and running nicely.
I'll work on a couple screen supplies next, then I have something in mind to try in place of the diodes, but will refrain from sticking my foot in my mouth again till I do some more research.
Old 23rd November 2009, 12:43 AM   #604
GK is offline GK  Australia
Come to think of it, you could make it work if you really wanted to by loading the LM317 voltage regulator with a resistor that draws more than the maximum cathode current.
Old 23rd November 2009, 03:49 PM   #605
TheGimp's Avatar
I was thinking of using a string of LEDs to drive the base of a NPN with it's emitter tied to ground and a resistor from base to ground to set the bias current of the LED string, collector tied to top of LED string.
Would the transistor amplify the noise of the LEDs and would result in more noise than the LEDs alone.
Bias the LEDs for 10mA.
Now I need 40mA from the collector so base current will be 40ma/Beta.
Most of the LED current and noise would be in the bias leg. The only portion in the collector of the transistor would be the amplified base drive. Both the noise and dc current should be beta times that injected in the BE junction.
This should not end up much noisier than the LED strings together should it?
Or do the values of the parallel strings of LEDs form a Square root of the sum of the squares function?
Old 23rd November 2009, 05:35 PM   #606
Yvesm is offline Yvesm  France
Yvesm's Avatar
I've routinely used that configuration as shunt regulator, wich is nothing else than a voltage source or a "Zener Booster"
And with Varistor as voltage reference:
Should work with LED string also but I can't tell about noise . . .
Yves.
Old 23rd November 2009, 06:21 PM   #607
TheGimp's Avatar
I've used suppression diodes like the 1.5KE350 as a HV ref diode for regulation and had thought about MOVs (Metal Oxide Veristors) that are used across power lines for noise suppression, but thought they would have too loose of tolerance. I'll look at the L14K60 series.
Does anyone have a link to Bas's article? the link http://basaudio.net/diymag.htm
from post 86 is 86'd.
I'm trying to find out how Sy measured the z of the LEDs adn can't find it in this thread so I presume it is outlined in the article.
Old 23rd November 2009, 06:57 PM   #608
Yvesm's Avatar
Yes, tolerance is wide, but thermal drift is much lower than a zener !
Old 23rd November 2009, 07:04 PM   #609
SY's Avatar
SYclotron Audio » The Red Light District
Old 23rd November 2009, 07:16 PM   #610
TheGimp's Avatar
Thanks Sy.
Red Light District/Baby Huey (EL84 P-P) Output Iron dsavitsk Tubes / Valves 3 14th February 2009 02:21 AM
Red Light District Amp Screen Reg mach1 Tubes / Valves 20 28th February 2007 10:37 PM
Rogers Cadet III to SY's Red Light District or Gingertubes's Baby Huey jkeny Tubes / Valves 24 22nd January 2007 10:28 PM
Page generated in 0.11740 seconds (78.88% PHP - 21.12% MySQL) with 11 queries
