| diyAudio Sponsor | ||
#501 |
4 is pretty close to the cutest age, no doubt!
With a 6V heater winding, the EL84 heaters are all in parallel. The ECC81 heaters are 12V, but they have a center tap at pin 9. So they can also be driven by the 6V winding by connecting together pins 4 and 5 and attaching one end of the 6V winding to pins 4/5 and the other end to pin 1. You still need to bias up the winding by the voltage divider (the 200k/51k pair). If your 6V winding has a center tap (i.e. 3.15-0-3.15), that's the spot to do it. If it doesn't, you can create an artificial CT by connecting two 47R-100R in series, connect them across the winding, then attach the bias voltage to their junction.
"...we stumble and get up, we are sad, confident, insecure, feel loneliness and joy and love. There is nothing more; but I want nothing more.” - Christopher Hitchens 1949-2011 |
#502 |
Splendid! Thanks SY.
#503 |
I think SY meant pin 9, not pin 1.
Hey is for horses. |
#504 |
That's right; I shouldn't type before I have my coffee.
#505 | |
Thank you for a nice to read article and for sharing your interesting design!!
Quoted from http://syclotron.com/?page_id=33 : Quote:
I also have a couple of additional questions. Sorry if they have been asked before but this is a long thread... 1. For simplicity I would be tempted to use a lower voltage for the input tubes. If I remember correctly you have said that the higher voltage is needed for gain reasons. Would this in practice mean that only a part of the output power can be used? Could the issue be solved with a preamp with gain or would that overdrive the input stage? 2. Could a toroidal power transformer be a good candidate for OT? At least the DC currents need to be matched very well. Is separate screen supply regulators for each tube the best solution for accurate matching? Is there other possible solutions? Are there specific reasons why I shouldn't use a toroid as OT?
-thomas s |
#506 |
I haven't heard much interest in PCBs- I have been wanting the post the PCB stuff for the screen regulators but for a variety of bad excuses, haven't done so yet. I promise I will... I would love it if someone would do a PCB design for the input stage- it would easily be adaptable to other designs like the Bevois Valley or make a nice input stage for an ST-70 rebuild.
I am totally incapable of PCB design, so in the words of Blanche Dubois, "I have always relied on the kindness of strangers." If anyone wants to do it, I have no objections to them selling it, as long as they give me one or two to try out. The higher voltage is needed for both gain and swing. If you run it lower, the distortion will increase since the first stage will be starved and the second will have insufficient cathode to plate voltage for linearity. But the current requirements are low, so it doesn't really add up to much expense. I haven't tried toroids (though a local guy has offered me some), but there's nothing special about this design that would make it any more or any less friendly to toroids than any other push pull. I absolutely would use separate screen regulators in that case- toroids are very, very finicky about any imbalance in idle current.
#507 | ||
These transformers cost $29 and have a huge VA rating, and plenty of heater power Quote:
I could be talked in to doing them, but really only if I knew there were enough people that wanted them, and if someone else picked up the tab for ordering and assembling a round of prototypes (which would end up being under $50 plus parts for a single set. I can be emailed at 01312009@ecp.cc -- that email address will be disabled after Jan 31)
http://www.ecpaudio.com |
#508 |
I've already got a PCB design for the regulators and LEDs (thanks to pinkmouse), but not the driver or the raw supply. I'd agree, the output tubes should not be on a PCB. Perf metal would be my first choice for mounting the sockets.
#509 | |
The circuit is similar to the RLD or the Bevois Valley. The driver (12AT7) power supply (5AR4) and the output tubes (EL84) are all on the PC board. I agree that output tubes on a PC board used to be a problem. With modern ceramic sockets on FR4 board material it is no nonger a problem. The Simple SE dissipates far more heat than this board, they have been in use for two years without issue. My personal unit runs EH KT88's at 40+ watts each. The only toasty thing in the amp is the poor overloaded power transformer, hot, but still running! The Simple P-P was designed for the usual cathode resistors and bypass capacitors, and the PC board is laid out for those components. I made provisions for LED's on the PC board, but not a bunch of LED's. I have found that 3 or 4 jumbo blue or white 1/2 watt LED's in series on each cathode works great. The prototype board can be seen lighting up the whole room using white LED's from the flash of a camera phone in the following thread. Simple P-P 84 proto When I decided to do the Simple P-P, I knew that there would need to be two P-P designs. There is a "Simple" version, which was just sent out. There is also a "not so simple" version. I have done a layout of a prototype PC board and started fabrication. I can't be sure what the final version will look like, but this one is a 4 by 5.5 inch board that contains the driver circuitry for a single channel. There are no power supply or output tubes on the board. Why? This board is intended for "universal" applications. Output tubes from the 6L6 types up to large transmitting tubes. Screen drive and cathode follower applications are supported as well. The power supply is off board since there are different requirements depending on output tube choice and circuit topology. A power supply board is being laid out now for some glowing sweep tube experiments. The circuitry is not unlike the Crystal Palace driver, except the cathode followers are now mosfets and the bipolar CCS's are now 10M45's. 9 pin tubes are used but an octal version is also planned. The prototype has provisions for topology modifications which may be used in screen drive and cathode follower applications. Not all of these features will make it to the final version. Testing will progress over the next few weeks.
Too much power is almost enough! Turn it up till it explodes - then back up just a little. |
#510 | |
| Red Light District/Baby Huey (EL84 P-P) Output Iron | dsavitsk | Tubes / Valves | 3 | 14th February 2009 02:21 AM |
| Red Light District Amp Screen Reg | mach1 | Tubes / Valves | 20 | 28th February 2007 10:37 PM |
| Rogers Cadet III to SY's Red Light District or Gingertubes's Baby Huey | jkeny | Tubes / Valves | 24 | 22nd January 2007 10:28 PM |
| Page generated in 0.17528 seconds (81.75% PHP - 18.25% MySQL) with 11 queries |
