diyAudio Sponsor
Old 15th June 2006, 11:23 AM   #31
SY's Avatar
Evangelos, my comments on the sound will be in the article that Bas is publishing. I'll say briefly that you will not believe that this is a 15W amp. There are several tricks (the LED array is one of them) which optimize the overload recovery characteristics so that clipping is almost un-noticeable.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 15th June 2006, 04:33 PM   #32
Variac is offline Variac  United States
diyAudio Editor
Variac's Avatar
I've never made a tube amp. This one might just be what pushes me to do so.
Poobah, The second symbol has four "feet" Which one are you referring to? We could refer to them as 1 is extreme left and 4 is extreme right.
Old 15th June 2006, 04:36 PM   #33
anatech is offline anatech  Canada
anatech's Avatar
Hi Mark,
Do it!
Even simple ones are rewarding.
-Chris
Old 15th June 2006, 05:25 PM   #34
EsE is offline EsE  Norway
I'm also looking for a good amp to build. Wich transformers do you recommend for this amp? And I've never seen a screen like that before..
Old 15th June 2006, 05:33 PM   #35
SY's Avatar
You want something which is 8k plate-to-plate with a 15W or better rating. I used Dynaco iron and also tested UTC LS series. Both worked great. The next few will use James.
By adjusting the RC network on the plate of the first stage, you should be able to get any decent OPT of the right impedance to work.
Old 15th June 2006, 05:52 PM   #36
pinkmouse's Avatar
SY, you may have missed my question, but is there a reason you dropped the leds down from 7x7 to 7x6?
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 15th June 2006, 05:59 PM   #37
SY's Avatar
I did miss it, sorry. The answer is a screw-up in the drawing.
As it happens, there's not much difference between 6 and 7 strings, about 5.5 ohm versus 4.5 ohm.
Old 15th June 2006, 06:11 PM   #38
poobah is offline poobah  United States
poobah's Avatar
Variac,
You got it right bud... EC's layout was missing the small leftward extension on the bottom of the 3rd foot.
I have no dictionary with that symbol. The missing extension might change the meaning from "girl of service" to "cow for hire".
Old 15th June 2006, 06:42 PM   #39
EC8010 is offline EC8010  United Kingdom
EC8010's Avatar
And I thought that little squiggle was a drawing error...
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 15th June 2006, 07:29 PM   #40
"cow for hire" "red-light district" Oh My!
None of us are leaving this world alive. Enjoy it responsibly as you may.
Red Light District/Baby Huey (EL84 P-P) Output Iron dsavitsk Tubes / Valves 3 14th February 2009 01:21 AM
Red Light District Amp Screen Reg mach1 Tubes / Valves 20 28th February 2007 09:37 PM
Rogers Cadet III to SY's Red Light District or Gingertubes's Baby Huey jkeny Tubes / Valves 24 22nd January 2007 09:28 PM
Page generated in 0.11435 seconds (74.92% PHP - 25.08% MySQL) with 11 queries
