diyAudio Sponsor
Old 15th June 2006, 01:45 AM   #21
mod_evil's Avatar
Send a message via MSN to mod_evil
This amp will be a circus! tsc tsc tsc...
Brazilian Tube Amp Builder.
Old 15th June 2006, 03:50 AM   #22
Variac is offline Variac  United States
diyAudio Editor
Variac's Avatar
Building on EC's efforts, 86 LED's. One LED on each symbol could be used as a standby indicator
You have to scroll to see it with my pdf reader
Old 15th June 2006, 04:20 AM   #23
diyAudio Editor
Variac's Avatar
Maybe easier to see:
Old 15th June 2006, 05:51 AM   #24
poobah is offline poobah  United States
poobah's Avatar
Good detail work Variac,
The cat missed one swish on the feet of the second symbol.
My infinitely limited knowledge of Kanji tells me that could be huge.
The first symbol means "city" or "city of". I'll leave it to everyone's imagination as to what the second symbol means.
Old 15th June 2006, 06:15 AM   #25
SY's Avatar
Well, it IS the name of Tokyo's Red Light District.
"...we stumble and get up, we are sad, confident, insecure, feel loneliness and joy and love. There is nothing more; but I want nothing more.” - Christopher Hitchens 1949-2011
Old 15th June 2006, 06:19 AM   #26
poobah's Avatar
SY,
We're workin' on it... asbestos we can.
Old 15th June 2006, 08:09 AM   #27
kenev is offline kenev  Greece
kenev's Avatar
SY,
Nery nice and interesting project.
What about some impressions on the sound of this amp?
Regards, Evangelos
Old 15th June 2006, 08:24 AM   #28
pinkmouse's Avatar
Well, the original version I saw had another parallel row, 7 x 7 x 2, giving us 98 leds to play with...
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 15th June 2006, 11:07 AM   #29
Merlinb is offline Merlinb  United Kingdom
LED's are notioriously unreliable when run in series or parallel from the same supply without individual surrent limiters- just a warning.
Won't a 133k anode resistor on the first ECC81 triode be pushing way into non-linear operation?
You might want to add a build-out resistor to the cathode of the cathodyne for balanced output.
Old 15th June 2006, 12:20 PM   #30
SY's Avatar
Quite the contrary, that's a particularly linear spot to operate it. At the full 11V peak output needed to drive the output stage, THD of the voltage amp is less than 0.03%.
Regarding LED reliability, you might check out what Bob Pease had to say in his book "Troubleshooting Analog Circuits."
Red Light District/Baby Huey (EL84 P-P) Output Iron dsavitsk Tubes / Valves 3 14th February 2009 02:21 AM
Red Light District Amp Screen Reg mach1 Tubes / Valves 20 28th February 2007 10:37 PM
Rogers Cadet III to SY's Red Light District or Gingertubes's Baby Huey jkeny Tubes / Valves 24 22nd January 2007 10:28 PM
Page generated in 0.10924 seconds (72.99% PHP - 27.01% MySQL) with 11 queries
