diyAudio Sponsor
Old 14th June 2006, 12:44 PM   #1
Default Balanced 300B output for headphones or loudspeakers?
What do you think about balanced output power amplifier stage for headphones with direct heated 300B vacuum tube?
Find some interedting reading here
http://www.hiendfi.com/phpBB2/viewtopic.php?t=816
I don't understand reasons for that kind of amplifier.
It's possible to drive loudspeakers that way?
Borut
AMPLIFIER ( MIC imput, HEADPHONES output)?? medogrizli Solid State 1 28th May 2007 12:31 PM
Headphones output to line level Simpleton Parts 1 13th May 2007 09:54 PM
sound of 45 v. 205d v. 2a3 v. 300b for headphones dsavitsk Tubes / Valves 22 13th January 2006 05:39 AM
Ok to run high-end headphones with amp output? The Paulinator Solid State 15 17th April 2004 07:08 PM
Enough about loudspeakers.... let's talk headphones Lisandro_P Everything Else 3 30th June 2002 11:42 AM
Page generated in 0.06448 seconds (63.44% PHP - 36.56% MySQL) with 10 queries
