| diyAudio Sponsor | ||
Does anyone have an opinion on the importance of quality power transformers? I am working on a project that will use electra print transformers for output transformers, and I am wondering if it is worth the extra money to use an electra print power transformer as well, or if a hammond will be just as good?
#2 |
check out those low dcr posts at audioasylum. apparently the answer is neither. the best are those $30 500va control transformers that you can bid on ebay any day.
#3 |
I now use the 3XX series of Hammonds, the ones that have dual primaries and are specified for 50Hz use. These are about 30% larger than the comparable 2XX series, much quieter, (actually very quiet) and don't get very warm at all on 60Hz. Seem better put together in general. They aren't cheap, but they aren't too expensive relative to the custom types they are competing against.
I used to OEM all of the power transformers I used, but at least for conventional power transformers the 3XX series seem competitive.
www.kta-hifi.net |
| Revealing sound quality differences | maraudingtechie | Everything Else | 4 | 10th May 2009 07:59 AM |
| Aleph 2 Differences in power consumption | Thago | Pass Labs | 4 | 22nd January 2008 09:17 PM |
| a thread on Transformer quality | Stefanoo | Pass Labs | 53 | 28th August 2007 05:42 AM |
| Quality Control differences = variations in sound quality? | KT | Class D | 0 | 14th November 2004 06:51 AM |
| Page generated in 0.07688 seconds (70.13% PHP - 29.87% MySQL) with 10 queries |
