| diyAudio Sponsor | ||
my main transformer's 5V line is limited to 2A which limits the tubes that I can use. I have a 5V4G (5V@2A) now but it would be nice to have other options like 5U4G (5V@3A).
I have a 2nd transformer (that has 2 secondaries) which will be used to heat up 8CG7 (8.4V@450mA). I am hoping I can use the other secondary to heat up rectifier tubes using 5V. Thanks for the help ps. I know that tube data mentions AC/DC heaters can be used. but my experience with tubes amps is very limited and most schematics I've seen uses AC heaters. thanks again |
#2 |
You can use a GZ34/5AR4 with a 2A winding, it only draws about 1.9A. It will also give you the lowest voltage drop of all tube rectifiers.
#3 |
I've used regulated DC for DH tubes and have yet killed one.....
OK, I did blow up a 45 before I realized the meaning of soft-start
#4 | |
I am planning to use one of the regulator chips from the LM317 family (higher current rating). would this be suitable? if not, can you share your schematic? thank you |
#5 | |
#6 | |
#7 |
Resistors is all I use. Chose the value for warm running, as the filaments are lower in R when cold.
#8 |
I have a 9V secondary.
so I need to drop 4V from it. 4V / 3A (current rating for 5U4G) = 1.33ohms (5x 6.8ohms 5W in parallel) 4V / 2A (current rating for 5V4G) = 2ohms (5x 10ohm 5W in parallel) Is my calculation correct? thank you |
#9 | |
John |
#10 |
Also, keep an eye on the insulation rating of your 9V transformer. It may not be rated for safe operation with a winding floating at B+ voltage.
| Simplest Tube Regulated PSU? | pftrvlr | Tubes / Valves | 3 | 1st August 2007 11:35 AM |
| Anybody heard about Tarzian Silicon Rectifier for Tube Rectifier Replacement? | zxx123 | Tubes / Valves | 4 | 21st February 2005 04:02 AM |
| Does the type of rectifier matter with regulated ps? | mateo88 | Chip Amps | 7 | 28th October 2004 09:03 PM |
| Tube rectifier for VDIGC tube psu | ebijma | Chip Amps | 2 | 11th March 2004 04:02 PM |
| Regulated vacuum tube rectifier cct. | Circlotron | Tubes / Valves | 5 | 14th May 2003 03:21 PM |
| Page generated in 0.23773 seconds (51.17% PHP - 48.83% MySQL) with 10 queries |
