diyAudio Sponsor
Old 9th June 2006, 05:21 AM   #1
jarthel is offline jarthel  Australia
Default motor run caps in the output? good or bad idea?
in the aikido circuit (specifically the headphone schematic), it uses an output capacitor.
I have search the forum about using motor run caps and all I've came across are references to using them in the power supply.
Has anyone used them in the output?
thank you for the replies.
Old 9th June 2006, 05:26 AM   #2
jamesjung21's Avatar
I will recommend it if you will use GE motor caps
Old 9th June 2006, 05:26 AM   #3
PSz. is offline PSz.  United States
PSz.'s Avatar
I use them as a first order filter on my compression drivers, so I don't see why they would be problematic as an output cap so long as you have sufficient capacitance for the application.
regards,
PSz.
Old 9th June 2006, 05:30 AM   #4
why GE?
at the value that I want, I can only find ASC.
Old 9th June 2006, 05:47 AM   #5
It's my personal sonic preference
I think they usually use paper... am I correct...?
Is the value less than 0.47uF ...?
Old 9th June 2006, 05:48 AM   #6
yes. it's paper
Old 9th June 2006, 05:50 AM   #7
Is the value less than 0.47uF...?
Old 9th June 2006, 05:50 AM   #8
no. more like 47uF
Old 9th June 2006, 05:54 AM   #9
Oh, I see why... If GE makes 47uF, they will be awfully large and rare
Are you trying to stick with your local part sources...? (Jaycar at any chance? )
Old 9th June 2006, 05:59 AM   #10
my local part sources are ebay, thlaudio, partsconnexion and percy.
farnell and rs non-audio quality stuff. dick smith for those things that are not really important such as heatshrink.
ps. I found a 40uF GE. I have a feeling it's not enough.
Bipolar stepper motor idea for custom turntable... binspaul Analogue Source 0 7th April 2009 09:43 AM
ESR of motor-run caps? JoshK Tubes / Valves 12 14th December 2007 03:17 AM
Motor caps croccodillo Tubes / Valves 13 1st December 2005 12:44 AM
AC Motor Start Caps for PS use gilid Tubes / Valves 44 28th June 2004 11:35 PM
Page generated in 0.08477 seconds (82.70% PHP - 17.30% MySQL) with 11 queries
