| diyAudio Sponsor | ||
#21 | |
According to Philips datasheet the max voltage between heater and cathode is 100V, (Philips Electron tubes, March 1975) Regards Hans |
#22 | |
the connected circuit will used about 70mA. does that mean the EL34 is not suitable? how did you find out about 65V and 50mA? can you tell me what graph can I find such info? Thank you very much |
#23 |
Look here http://www.mif.pg.gda.pl/homepages/f...129/e/EL34.pdf
at page 9, you can see that an EL34 triode connected will pass ~50mA at 65V and 0V on the grid, it can pass more at positive grid voltage but then it will draw current from the reference Zener chain which will affect the output voltage. A 6AS7 will pass ~150mA already at 40V. with 0V on the grid. Find a better design which use feedback to get a better stabilised voltage. Regards Hans |
#24 | |
thank you. the page you linked above contains circuit that are for "advance DIYers" IMO
#25 |
would I encounter problems using the circuit above (still using 6as7) if my target Vout is around 150V?
#26 | |
Regards Hans |
#27 |
Did anyone notice that the reg circuit in question uses BOTH sections of a 6AS7? So when Eric suggested an EL34 would that mean two EL34's in //?
Regardless the regulation of the circuit is poor, in otw not that great. That's not to say it wouldn't work as far as for his Brute Force Line Stage. It's a pretty darn simple series pass regulator, about as simple as you could get. To get better regulation one would add an error amplifier which would add to it's complexity unfortunately. There are other tubes, triodes or triode strapped pentodes that can be used. From the article I believe one reason he used the 6AS7 was for it's looks. @jarthel here's a nice tutorial by Steve Bench: http://members.aol.com/sbench/reg1.html Cheers Wayne
#28 | |
I have read that article twice already. very good one. He mentioned changing R1 and R2 to change Vout but he never said what formula to use. I was thinking simple voltage divider was used which according to my search is: Vout = Vin x R2 (R2 + R1) But for a newbie like myself, that's only a guess. It's probably right but most likely it's wrong. Thank you all for the help |
| Help, Need circuit for BWD 216a tube power supply | OzMikeH | Parts | 1 | 23rd February 2008 03:22 AM |
| PP EL34 circuit wanted | Norris Wilson | Tubes / Valves | 3 | 9th August 2007 12:29 PM |
| power supply schematic with a 6080 used as a "pass tube" | jarthel | Tubes / Valves | 1 | 27th May 2006 04:41 PM |
| EL34 Feedback circuit | dr._sleep | Tubes / Valves | 3 | 17th October 2005 06:01 PM |
| Best place to place bleeder resistor in a power supply? | G | Tubes / Valves | 13 | 4th August 2004 10:26 AM |
| Page generated in 0.10823 seconds (76.16% PHP - 23.84% MySQL) with 11 queries |
