diyAudio Sponsor
Old 8th June 2006, 02:08 AM   #11
jarthel is offline jarthel  Australia
Originally posted by showdown
I'm sure someone can correct me if I'm wrong, but this is what I'm thinking:
last question: Do I still need R3 (20K 10W) as mentioned in the schematic?
thank you everyone for the help
Old 8th June 2006, 02:54 AM   #12
cogsncogs's Avatar
Yes, absolutely! Otherwise you would have all of your PS current across the zeners which would fry them! The resistor is neeed as you are taking the voltage drop across it as the voltage reference which is applied to the (control) grid.
Wayne
Edit: I was assuming you meant a short for R3. But still you need it as stated because you will need to have current across the resistor/zener diode string.
Old 8th June 2006, 03:22 AM   #13
cogsncogs's Avatar
jarthel
This may help - a picture:
Wayne
Old 8th June 2006, 03:58 AM   #14
I really appreciate the help.
thanks everyone
Old 8th June 2006, 04:42 AM   #15
diyAudio Moderator Emeritus
ray_moth's Avatar
Firstly, jarthel, I apologise for using jargon, assuming you're familiar with pentodes. Suppressor is an abbreviated name for the suppressor grid, also called Grid 3. It's what makes the difference between tetrode and pentode.
Secondly, can I squeeze a quick question in here, please?
Do you guys believe that the EL34 can actually do the job as a regulator pass tube here, or will it incur too high a voltage drop between plate and cathode?
Old 8th June 2006, 04:56 AM   #16
thank you asking the question.
I just believed it would work as the article was written by someone vastly more knowledgeable than myself.
Old 8th June 2006, 06:07 AM   #17
wrenchone's Avatar
If you are trying to sub an EL34 fpr a 6AS7 as a pass tube, one of the first things you want to check is the heater to cathode voltage rating. The 6AS7/6080 has a high filament to cathode breakdown rating - I don't recall the rating for the EL34 being anything special. If you have an isolated filament winding feeding the pass tube, all is well. If not, beware....
Old 8th June 2006, 06:23 AM   #18
Good point!, with 250VAC giving a maximum raw DC of ~340V there will be only max 30V over the tube, a EL34 can only pass about 20mA at this voltage and then there is no margin for drops in line voltage.
I would recommend a higher voltage from the transformer and to build a better power supply with better regulation using at least a pass tube and a control tube, I have been very successful with a design similar to this http://www.bonavolta.ch/hobby/en/aud....htm#Tubes%201
although I use a 6BM8 with the triode as control tube and the pentode triode coupled as a pass element, I also use gas regulator tubes as reference.
Regards Hans
Old 8th June 2006, 06:31 AM   #19
from what I understand, I should not worry if the EL34 has its own secondary and no other tube heater is connected to that secondary. is this correct?
looking at the datasheet, 6AS7 has 300V of heater-cathode voltage limit. While the 6CA7 has 100V limit.
I looked at Phillips and Mullard EL34 datasheet and I can't deduce the heater-cathode boltage.
Old 8th June 2006, 06:34 AM   #20
I won't be using a 500-0-500V xformer though. It'll only be a 280-0-280.
Help, Need circuit for BWD 216a tube power supply OzMikeH Parts 1 23rd February 2008 03:22 AM
PP EL34 circuit wanted Norris Wilson Tubes / Valves 3 9th August 2007 12:29 PM
power supply schematic with a 6080 used as a "pass tube" jarthel Tubes / Valves 1 27th May 2006 04:41 PM
EL34 Feedback circuit dr._sleep Tubes / Valves 3 17th October 2005 06:01 PM
Best place to place bleeder resistor in a power supply? G Tubes / Valves 13 4th August 2004 10:26 AM
Page generated in 0.12605 seconds (79.63% PHP - 20.37% MySQL) with 11 queries
