diyAudio Sponsor
Old 7th June 2006, 02:59 AM   #1
jarthel is offline jarthel  Australia
Default help with a transformer
in euphoniaaudio.com (http://euphoniaaudio.netfirms.com/ea...de5656195a8f48),
secondary4 is rated at 0-5v-6.3v @ 2A.
but when I read the accompanying PDF datasheet on the same page, I get feeling that sec4 is rated 5V @ only 1.5A. I'm not sure what is the rating at 6.3V.
can someone help clarify?
thanks for the help
Old 7th June 2006, 05:50 AM   #2
diyAudio Moderator Emeritus
ray_moth's Avatar
Looks like they made a mistake somewhere, because all the low voltage secondaries are stated to be 2A on the web page but only 1.5A on the pdf. You probably should contact them and ask for clarification.
If the 5v tap is 1.5A on secondary 4, then the 6.3v tap on secondary 4 will also be 1.5A (unless it's a very strange winding, in which case the 6.3v could be less than 1.5A - certainly not more).
Old 7th June 2006, 06:06 AM   #3
thanks for the reply.
I emailed euphonia thrice but no reply at all.
Old 7th June 2006, 09:46 AM   #4
Send a message via MSN to firefart_1st
They might Dont Know !!!
that hapends to me aLOT...
the stores dont know or care for what they are selling...
music music music music
Using mains transformer as output transformer Elias Tubes / Valves 175 3rd November 2009 08:36 PM
Modulation transformer for a driver transformer? ironradio Tubes / Valves 6 28th December 2008 05:05 PM
filament transformer vs plate transformer contaxchen Tubes / Valves 10 14th January 2005 10:43 AM
toroid Transformer as power Transformer for tube tone Tubes / Valves 7 11th February 2003 08:57 AM
toroid Transformer as output Transformer for tube preamp? tone Tubes / Valves 15 2nd February 2003 04:36 AM
Page generated in 0.08467 seconds (68.88% PHP - 31.12% MySQL) with 10 queries
