Old 6th June 2006, 10:15 PM   #1
Default Re-attaching anode cap to 805 or 811A tube
Any suggestions to reattach the anode cap to an 805 or 811A tube is appreciated.
Thanks in advance!
Old 7th June 2006, 01:37 AM   #2
tubelab.com's Avatar
I used JB weld. It is a two part epoxy. It can be found at an auto parts store. Sometimes found in the automotive section at Wal Mart. Once it cures it is there forever, so make sure you get it right. Clean the solder out of the cap so that the wire sticks up through the hole, glue on the cap, aait about an hour, then solder the wire. Don't use so much glue that it squirts up through the hole, then you won't be able to solder the wire. It can be used to fix loose bases too.
Too much power is almost enough! Turn it up till it explodes - then back up just a little.
Old 7th June 2006, 02:00 AM   #3
CLS is offline CLS  Taiwan
How about the pins on the base? (not between base & bulb)
My EH 300B has loose pins, all of them. The electrical connections are OK, but physically loose.
The contact area between base & pin seems so small. Can epoxy really cure this?
Thanks in advance.
Old 7th June 2006, 02:37 AM   #4
Miles Prower's Avatar
Originally posted by tubelab.com
I used JB weld. It is a two part epoxy. It can be found at an auto parts store. [...] It can be used to fix loose bases too.
JB Weld: coolies! I have some 6V6s and a 6SN7 that're wobbly in their bases.
There are no foxes in atheistholes
www.dolphin-hsl.com
Old 7th June 2006, 02:54 AM   #5
billr is offline billr  New Zealand
Hi
I've actually done this on an 811 that i bought, pulled the anode cap off when pulling the plug off!
What I did was to sand back the wire that pokes out of the glass, then took a soldering iron to the top of the anode cap, melted all of the old solder out of it.
Then got the thing sizzling hot, held it with a pair of pliers, then flooded the hole, c./w wire sticking out with solder, let it cool, and bobs your uncle.
I made sure that the new anode plugs were not so tight the next time.
hope that this helps
I think that you can safely forget expoxy and all that stuff, you will put tension on the glass etc., and it will crack, I would have thought.
bill
Old 7th June 2006, 01:39 PM   #6
I tried the sizzling hot solder method a long time ago on an 811A. The wire is under tension when the tube is cold, and gets loose when the tube is hot. The seal failed after about a year and air got into the tube. I have two glued with JB weld that have survived for over a year, but I haven't been using them in a while. I guess either method is better than what I was doing, which was an aligator clip on the wire.
Anyone know agood MOSFET drive for RCA 811A Tube? Alastair E Tubes / Valves 9 25th August 2005 03:59 PM
attaching a headshell spooky1234 Analogue Source 4 23rd March 2005 03:07 PM
811A tube internal resistance ? Zoran Tubes / Valves 38 11th May 2004 07:33 AM
811a Tube Cap Size NickC Tubes / Valves 2 15th April 2004 09:47 AM
Not connecting grids/anode can hurt tube? Redemption Tubes / Valves 6 14th January 2004 11:20 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
