Hello,
I got my hands on a tube amplifier mabe by Philips, the HF10, i thought it also goes under the name of mozart (?). It is a mono 10W amp. The problem is that there are some components wandering around the case and I dont know where which one must be connected so I am searching for a schematic. If someone knows where to get it I'll be pleased to hear it. greetings, Hans-Willem |
#2 |
diyAudio Senior Member
Here is a link to a site where you can buy a circuit diagram: http://www.oldradioworld.de/advertis.htm There are several sources on the web available offering this kind of service for restoring vintage radio and such. Cheers,
Frank |
#3 |
If you know the tube lineup, you might be able to reconstruct it with a better circuit...
Got a pic?
#4 | |
http://home.planet.nl/~mhamm/Radio/apparatuur/hf10.htm it's the same as this one (approximately), mine houses 2 ECC83 tubes. I have it for some time now, never looked at it because its only one channel :/ |
| FS Alnico Philips AD3800M AD3800AM and Philips transformers | guglielmope | Swap Meet | 8 | 10th January 2011 11:28 AM |
| philips cd 880 philips cd880 service manual | 0519 | Digital Source | 4 | 28th August 2008 11:43 AM |
| Amp non working | covik | Solid State | 0 | 12th November 2006 08:12 PM |
| WTB Krell KSA Mk2- working or non working | Jozua | Swap Meet | 0 | 20th March 2006 11:14 AM |
| Non working GC | ShieldJaguar | Chip Amps | 7 | 31st October 2004 01:23 PM |
