Use of 12j1l and gu-50 tubes
Old 3rd June 2006, 03:17 PM   #1
gemby is offline gemby  Croatia
Default Use of 12j1l and gu-50 tubes
I just got around 70 pcs of 12j1l (http://www.tubecollector.org/12j1l.htm ) tubes and around 20 of gu-50 tubes ( http://www.tubecollector.org/r-gu50.htm )
Most of them are naked, without alu shield, some still has shield, all NOS tubes...
I have 2 sockets for GU-50 and around 15 sockets for 12j1l tubes.....
I fount some schematics for GU-50, does anybody know some link or schematics for 12j1l tubes? Some preamp, driver?
Old 3rd June 2006, 03:36 PM   #2
Here are photos of some of them :-)
http://gallery.galaksija.org/display...album=1&pos=13
http://gallery.galaksija.org/display...album=1&pos=14
Old 28th August 2008, 06:28 AM   #3
arensattic is offline arensattic  Netherlands
arensattic's Avatar
Default Schematics for 12J1L
Dear Gemby,
There are many schematics for 12J1L tubes on German and Russian websites. Using Babelfish, you can understand the accompanying text. Please note that the Cyriliic characters on Russian tubes are transcribed in different ways. Therefore, the 12J1L may also be called 12S1L, 12SH1L, 12Z1L or 12ZH1L (and the Russians may use their own Cyrillic letter).
For a first attempt, I would advise you to examine the following URLs carefully (with a search function):
www.jogis-roehrenbude.de
www.b-kainka.de
www.roehrentechnik.de
(I can also send you scans if you indicate what you would like to see)
Note also that the 12J1L is a Russian equivalent of a German tube called RV12P2000. Schematics for this military tube (a "Wehrmachtröhre") will work when you replace it by the 12J1L.
I have myself performed some experiments with the 12J1L, both for RF and LF purposes. I like the tube since it is very quiet and non-microphonic. But I would not remove the aluminium screen for better looks - since the screen is an effective protection against mains-induced hum.
Hope this helps !
Best regards from the Netherlands,
Aren van Waarde
(aka arensattic)
Real HiFi runs hot and has only one speaker unit per audio channel.
Old 26th October 2008, 11:15 AM   #4
soundbrigade is offline soundbrigade  Sweden
soundbrigade's Avatar
Send a message via MSN to soundbrigade
Aren: would GU50's work in your universal amplifier (the one with the EL156)? And use the GIT80 and POW80 transformers? (I am now considering monoblocks)
/Magnus
Due to economical cutbacks, the light at the end of the tunnel has to be switched off.
Old 26th October 2008, 05:17 PM   #5
azazello is offline azazello  Bulgaria
azazello's Avatar
http://sergeev21.narod.ru/gu50se.GIF
First tube - E 180F, plate curr./10-15ma/, or EF86 /15-20 ma/.
Second tube GU50, plate current 90 ma, bias - - 60-80 v.
Ra output transf. - 5 kom /Hammond 125FSE/.
Projects: OTL-OCL 6AS7 Gen. Electric, SEs 2A3 RCA, 300B JJ, 6S4S, 4P1L, EL11 Telefunken, 6AS7 RCA, 6S33S, 6S41S, 6S19P, E84L Siemens, E236L Telefunken, headphone ampl. OTL Loftin White 6AS7 RCA,... PPs 6005 Gen. Electric, EL34 Mullard, 6L6....
Old 26th October 2008, 06:06 PM   #6
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
No, EF80 and EF86 can't be used directly instead of 6J52P that is the last pentode developed for TV sets. Similar to E810F, but superior. It has 55 milliamperes per volt steepness.
Here is the info:
http://www.medrk.ru/uploads/doc/6zh52p_r&e.pdf
12J1L is completely different tube, a redesigned Telefunken RV12P2000 (GU-50 is also redesigned Telefunken tube, famous LS-50)
I would consider 12J1L as a very ordinary pentode, exceptions are long life and very high reliability. Since it was designed for aircraft vibrations it may have low microphonic perception, but I did not test them in such sensitive places.
The Devil is not so terrible as his math model is!
Old 26th October 2008, 09:56 PM   #7
azazello's Avatar
Of course,EF80 and EF86 can't be used directly instead of 6J52P,
but Gemby can try to use its, or EF861, 6P15P, 6E5P or triods EC86, 6S3P, 6S4P.
Use of 12j1l and gu-50 tubesHide this!Advertise here!
Tube Noob! need help with tubes lots of tubes therapy_fan Tubes / Valves 15 29th January 2009 09:01 PM
WTT: Various tubes for 6CA4/EZ81 rectifier tubes GordonW Swap Meet 4 27th August 2008 12:37 AM
CV428 tubes (Loktal 807) tubes FS mobyd Swap Meet 3 2nd January 2008 11:26 AM
FU 13 tubes thomas-NGU Tubes / Valves 13 1st July 2007 11:38 AM
many new tubes and tubes meter for sale elviukai Swap Meet 4 30th October 2003 09:22 AM
Copyright ©1999-2017 diyAudio
