| diyAudio Sponsor | ||
I picked up a Philips AG-9016 integrated amplifier and want to convert the silly 5 pin cinch inputs to rca's. I have the schematic, but can't make sense of the wiring. Anyone here that can tip me in the right direction?
Here's a link to a photo and a schematic of the amp. link from forum |
#2 |
This is an old thread but I figured I'd bump it since I'm looking for the same info. I'm very green to this so any help is greatly appreciated.
#3 |
You may start by removing the stereo-mono switch, and the wiring and resistors associated with the tape-out. Then you are left with 3 pairs of shielded wires to the input selector which should be easy to follow.
Turn on the amp with speakers connected, and use your finger as a [hum] signal generator. This make it easy to sort out the input wires. Svein. |
| Upgrades for D1 | sixty9 | Pass Labs | 12 | 1st November 2011 10:15 AM |
| FS Alnico Philips AD3800M AD3800AM and Philips transformers | guglielmope | Swap Meet | 8 | 10th January 2011 11:28 AM |
| t-amp upgrades | Code | Class D | 1 | 14th January 2006 04:12 PM |
| Need Help. Anyone with Philips AG 9016?? | Chrisssssssss | Tubes / Valves | 6 | 12th January 2006 06:31 PM |
| Page generated in 0.06882 seconds (67.55% PHP - 32.45% MySQL) with 10 queries |
