diyAudio Sponsor
Old 2nd June 2006, 03:11 PM   #1
jarthel is offline jarthel  Australia
Default tube amp in a PCB with a toroidal xformer beside it?
should i worry? I'm worried I'll get hum on the output. pcb is 4in 10" x 4" while the toroid is abour 3.5" and the chassis is 8" wide inside.
thanks for the help.
Old 2nd June 2006, 03:46 PM   #2
poobah is offline poobah  United States
poobah's Avatar
Relax,
The beauty of a toriod, and one of its selling points, is that it does not radiate much in the way of magnetic fields... the field stays in the donut.
You still can have electrostatic radiation and capacitive coupling into surrounding circuits. You can always put a grounded shield around (foil) the toroid if this is a problem.
How best to use the PSU xformer I have Steerpike Tubes / Valves 1 12th November 2008 09:27 PM
Output Tube biasing for Toroidal Output Transformer gingertube Tubes / Valves 7 17th April 2005 04:40 PM
Think these are useful -- huge xformer?! rif Parts 21 13th August 2004 10:00 PM
Best Transformers (Encapsulated Toroidal or Open Frame Toroidal) Rixsta Pass Labs 10 23rd April 2004 03:41 AM
xformer for GC meta Chip Amps 4 4th July 2003 07:55 PM
Page generated in 0.07132 seconds (65.15% PHP - 34.85% MySQL) with 10 queries
