| diyAudio Sponsor | ||
I have been looking at some equipment lately made in china.Alot of the equipment is only set up for 220-240v.
Is there a downside to using a step up/down converter.I see many for sell on ebay 100 -5000 watt. I would think a benefit would be more line filtration. But never the less china has some extremely good deals on equipment i would like to try out. thanks
In the beginning there was music |
#2 | |
If you own your home, you could install a 15A 240V AC branch circuit. The sort bigger window air conditioners use. The plug is nema 6-15P and looks like -.- instead of the usual '.' prong pattern. It would still be 60Hz but unless it is a record player or clock expecting 50Hz for rotation speed accuracy, 230V 50Hz equipment will work fine on 240V 60Hz. Both sides of this line will be hot, but well designed equipment will still be safe. Post edited to remove suggestion that could have killed an unwary reader. |
#3 | |
Aerodynamics are for people who can't build engines. Enzo Ferrari |
#4 |
How about just a plain warning: don't do it! ![]() Better to pay an electrician a couple hundred bucks to do it for you.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#5 |
thanks guys
I am going to purchase a top quality step trans to convert 120v to 240v Hopefully that will be all i need.
#6 |
I have edited this thread. Those who made the posts and the comments will know why. Please remember that people who read a thread may have abilities ranging from knowledgeable but wary, all the way down to over-confident neophyte. I'd like to keep the over-confident neophytes alive until they can be converted into wary but knowledgeable...
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference... |
#7 |
Edit accepted. Forgot that not everyone here routinely works with high voltage.
#8 |
I am not sure how high the watts on the trans should be ,but this is one i am looking at.
http://www.international-electrical-...formers-2.html I am looking into purchasing DUSSUN V6i ex KORSUN V6i HighEnd HiFi Integrated Amplifier from china--cheapest way to purchase the unit. Also looking at some other various tubes amps that are very cheap to try out ,but they are 220v I wanted a step transformer unit that i could adjust the volts.And meter gauge that can tell me what the volts are going in and going out to the amp. The main thing is being able to set the trans for 220,230 or 240v
#9 |
No, no, you really don't want one of those! A voltage regulating transformer (known as a constant voltage transformer in the UK) is a technically quite interesting device that relies on controlled core saturated to maintain the RMS voltage leaving the transformer more or less constant whatever the input. Unfortunately, despite the fact that resonant techniques are involved, the distortion on the output voltage is considerable.
When we rectify mains, we add huge distortion, so there's little point in fretting about distortion in that regard. However, we frequently apply AC directly to heaters, and distortion/noise on the mains can make its way into the audio via Chk and Rhk. OK, it's not usually a problem with power amplifiers, but why allow the problem at all? What you need is a nice old-fashioned EI 120V to 240V autotransformer of at least 1kVA rating. If you want to turn a necessity into a bonus, make it an isolating transformer that transforms from 120V to 240V and has a foil electrostatic screen between primary and secondary (this will greatly reduce the muck on the mains). You do not want a toroid. Don't worry about meters.
| What advantages running ported midbass if you are running a sub? | mitchyz250f | Multi-Way | 3 | 20th May 2008 02:34 PM |
| Wanted: DIY Paradise Charlize, OR Decware Taboo (220V), OR Almarro A205 (220V) | Jolojl | Swap Meet | 0 | 28th August 2006 11:31 AM |
| Running a 220v cd player on 110v | ark | Everything Else | 7 | 10th May 2006 03:32 PM |
| 12V-220V(ac) to 12V-50V(dc) | raszvan | Car Audio | 0 | 16th June 2005 08:28 AM |
| 220V 50hz | diyman | Digital Source | 5 | 3rd February 2003 05:50 AM |
| Page generated in 0.10927 seconds (80.14% PHP - 19.86% MySQL) with 10 queries |
