| diyAudio Sponsor | ||
Hello, I've just started with valves, all my knowledge is about transistors.
I have bought an amplifier single ended with EL84 and Don't know which valve is the driver so I posted a picture here asking if someone that really knows about this devices can recognize it. It is a 12ax7 or 12au7 or the like? The label was deleted. Thanks in advance for your help.
Jorge |
#2 |
another picture
Jorge |
#3 |
It's definitely in that series, and definitely NOT a 12AT7. If you can trace out the values of the plate and cathode resistors, it would be easier to pin it down exactly.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#4 |
HI SY, thanks for your prompt response
what values it is needed, voltages?, resistors?, what I need to trace exactly, I am @ work now, but I can trace tonight and inform late today or tomorrow. Thanks again!!!!
Jorge |
#5 |
Some times I know if you breath on the tube, getting condensation on it will make the numbers re-appear, kindof like writing a
Welcome to the world of tubes, its like the Hotel freaking California. you can check-out anytime you like, but you can never leave! you're going to be addicted to tubes for life! |
#6 |
Hi JORGETronic,
The plates appear to make that a 12AU7, longer than a standard 12AX7 for sure. I haven't seen a so called "long plate" 12AX7 in the flesh, so I can't say for sure. Fogging the glass is a last resort for me beyond sticking it in a circuit or tube tester. -Chris |
#7 |
If you break the envelope... we can take some measurements.
#8 |
You always take the direct approach poobah.
#9 |
Wookies do.
#10 |
Resistor values would do, voltage values would be a great confirmation.
Chris, I've got piles of old 12AX7s that look just like that. Wouldn't it be a kick if it turned out to be a 7247!
| Tube Noob! need help with tubes lots of tubes | therapy_fan | Tubes / Valves | 15 | 29th January 2009 09:01 PM |
| WTT: Various tubes for 6CA4/EZ81 rectifier tubes | GordonW | Swap Meet | 4 | 27th August 2008 12:37 AM |
| Tubes! | Geek | Swap Meet | 4 | 16th May 2008 06:20 PM |
| CV428 tubes (Loktal 807) tubes FS | mobyd | Swap Meet | 3 | 2nd January 2008 11:26 AM |
| many new tubes and tubes meter for sale | elviukai | Swap Meet | 4 | 30th October 2003 09:22 AM |
| Page generated in 0.10375 seconds (77.16% PHP - 22.84% MySQL) with 11 queries |
