diyAudio Sponsor
Old 31st May 2006, 08:58 AM   #1
Default 45 fans – expanded horizons upstream?
Has anyone done a 45 preamp?
. . or have any suggestions?
I am looking for a preamp circuit . . I have spare 45s (and using 45s might aid integration in a biamped system, with 45s on the tweets).
So what 45(?) preamp circuit do you suggest, preferably with priority to: dynamics, then detail, & 3rd (if not too conflicting) lack of harshness.
(The 45 doesn’t have any qualities that don’t suit it being in a preamp, eg microphonics?)
Any advice appreciated
Old 31st May 2006, 09:12 AM   #2
Hi Rick57
Here is a design using a 2A3 for line stage duties. A 45 seems to be half of a 2A3, so maybe it serves as inspiration
http://triodeguy.com/line_stage1.htm
Erik
Old 31st May 2006, 09:15 AM   #3
Miles Prower's Avatar
Default Re: 45 fans – expanded horizons upstream?
"The 45 doesn\u2019t have any qualities that don\u2019t suit it being in a preamp, eg microphonics?"
Just a u= 3.5. This is not preamp material since there is precious little voltage gain. You might get an Av= 3.0 if you use an active load. You'll get less if using passive, resistance loading.
There are no foxes in atheistholes
www.dolphin-hsl.com
Old 31st May 2006, 10:06 AM   #4
Hi Erik
Yes I believe the (later) 2A3 is a double (earlier) 45.
That 'line stage' does other things as well eg XO. If I can’t find a specific 45 circuit, I might contact the designer triodeguy to see if he can split/ adapt it?
Cheers
Old 31st May 2006, 10:17 AM   #5
> Just a u= 3.5
For a high efficiency system, I (like SY's "Heretical Unity gain line stage") am after little or no gain.
Maybe SY's could work (with changes of ??) with a 45?
Cheers
Old 31st May 2006, 12:52 PM   #6
jeff mai's Avatar
Instead of asking others to redesign circuits, why don't you take a stab at doing it yourself?
Old 31st May 2006, 10:22 PM   #7
Jeff
I got as far as looking at the tube parameters, the 45 is very different from the ECC88 (6DJ8). I’m a way off understanding SY's circuit, though it’s simplicity is appealing. Even to understand his thread, some time on the basics is Needed.
Rather than reinvent the wheel, I will first see if some one has done a 45 pre. If none has (successfully to ‘publish’), maybe there is something wrong with the idea.
Old 31st May 2006, 10:46 PM   #8
jeff mai's Avatar
Your previous post was an invitation for someone else to reinvent the wheel, so clearly you aren't totally opposed to the idea.
Old 31st May 2006, 11:06 PM   #9
That was a bit rich, I was feelin groggy at the time
I hear the RCA manual has a 45 circuit.
Though also maybe a 10 preamp sounds more punchy - maybe that is just more gain??
Old 31st May 2006, 11:12 PM   #10
pinkmouse's Avatar
Have you read Morgan Jones' book yet? It helped me a lot during my construction of SY's line stage.
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Passive Crossover Upstream of Amp? NV&H Multi-Way 3 20th June 2009 04:14 AM
Expanded PTFE PCB substrate? Petter Parts 4 4th April 2003 12:34 PM
amp fans sriegel Pass Labs 4 5th January 2002 11:10 PM
Page generated in 0.11416 seconds (79.13% PHP - 20.87% MySQL) with 11 queries
