diyAudio Sponsor
Old 31st May 2006, 07:11 AM   #1
Default 12B4a Cathode Follower
I read with interests the concept of 12B4a liine stage using LM317 ccs at the cathode.
I want to try a line stage having the output stage of using 12B4a as cathode follower. My preliminary idea of this cf stage is:
(a) Shunt regulated B+ of 175 volt to the plate of 12B4A;
(b) LM317 current regulated using 48 ohm resistor (25ma) connected between 12B4a cathode and the ground with 220uf (+.1uf) bypass cap;
(c) 12B4a grid tied to ground with 1M ohm resistor.
Does this work? Is this so simple?
I don't know how to figure out the resistance of the LM317 ccs and the grid voltage here. Do I need to put another resistor between the LM317 ccs (317 with 48 ohm reisstor) and ground in order to bias the 12B4a correctly.
Any help and suggestion is appreciated. Thanks.
Old 31st May 2006, 10:03 AM   #2
I have no idea about the technical side of your query, but why do you want to use the 12B4 as a cathode follower? I first used it 7 or 8 years ago as a line stage because it had low gain, low output impedance and reasonable linearity. What you want in a cathode follower is a combination of high gain and high transconductance to get a very low output impedance. I have used both EC91s and EC88s for this (both single triodes) and a lot of people use ECC88s in a White cathode follower circuit for even lower output impedance and good cable-driving qualities.
Old 31st May 2006, 11:09 AM   #3
Uchi Deshi's Avatar
It's wasting very good tube. Use Gary Pimm CCS and mu-follower configuration for low output impedance.
Best regards,
Rafal
Old 31st May 2006, 12:54 PM   #4
jeapel is offline jeapel  Canada
hi Uchi
Maybe can you help me with Gary Pimm ccs
If i understand in both case there is a buffer
12B4a(cathode follower) or irf820(mu-follower)
But what is the best sound and in your test when
you switch from just ccs (plate output) to
mu-follower output how is the sound because:
1- high mosfet Cin
2- no linear Cin with mosfet
thanks
Old 31st May 2006, 01:25 PM   #5
Brian Beck's Avatar
Default Caution about using 12B4 as CF
Usually you look for both high gm and moderately high mu for a CF. This is because the voltage gain of a CF is limited to mu/(mu+1). If mu is, say, 30 or higher (as in a 6DJ8) this factor is very close to one (about 0.97). With a low mu tube like the 12B4 (one of my favorites for common cathode use, BTW), this factor becomes 6.5/7.5 = 0.867. While this 1.2 dB loss may not be a problem, it does open the possibility for more second harmonic distortion since mu is now "more in the picture". Said another way, there is less negative feedback available for the CF. Whether this is sonically a problem or not is arguable. The 12B4 cathode output impedance (ignoring Rk for the moment) is about 1030/7.5 = about 140 ohms under data sheet bias conditions, and probably closer to 200 ohms under real world conditions. This is not bad, but a 6DJ8 can muster half of this value. As a side, if using a current source in the CF cathode circuit, I would NOT use a naked LM317. It's OK bypassed for common cathode service, as I showed earlier. You can use an LM317 with a simple cascode element (BJT, FET) above it to raise the output Z of the CCS at all frequencies. This gives the stability and predictability of the LM317 current setting based on a band-gap reference voltage and the cascode’s multiplication of the output Z.
Brian
Old 31st May 2006, 01:40 PM   #6
Uchi Deshi's Avatar
No, mu-follower configuration isn't buffer- gain isn't unity, but stage will have gain = tube mu.
In my preamp change from CCS to mu-follower CCS has given better dynamic and sound impact, it's caused by lower output impedance.
In Gary's CCS disadventages of mosfets(high and nonlinear Cin) are minimalized by cascode mosfet configuration with bias.
PS. Generally I don't like cathode follower sound, for me mu-follower with Gary Pimm's CCS is much better(more clear and more transparent).
Best regards,
Rafal
Old 31st May 2006, 03:38 PM   #7
"In my preamp change from CCS to mu-follower CCS"
Exactly like me Uchi i want to change my C4S ccs to
Gary mu-follower ccs to speed up my preamp.
Maybe not a buffer but am i completly wrong or the sound pass through the irf820 .
thanks for sound feedback on Gary mu-follower
Old 31st May 2006, 03:42 PM   #8
Thank you for your advice.
I am currently using a single-stage WE437a WOT (Lundahl transformer connected as 4:1) line amp. For the speakers, I am using horn speaker system of double 15" woofers per side and the cable connecting line amp and power amplifier is around 25' long. Therefore, I need a line amp of output impedance as low as practical. In my opinion and my previous experimentation, lower impedance can drive my speakers with more dynamics and speed and can make the amplified sound follow more closely to the original input music signal.
Hence, I would like to try a simple two stage design with the first stage as a pure voltage gain stage and the 2nd stage as the current output stage. For the output stage, I would try the cf which is simple and easy to implement.
Though there are many sayings that the cf is not good, I do hear a few line amp. using the cf which are sounding very good. I think it is the implementation which tell the differences.
Indeed I have tried experimenting cf using a 6EM7 (triode no. 2), EL504 (pentode) and even 6B4G (DHT) with the output transformer (20ma, 4:1) connected to their cathode as its load with very good results.
My own experience on achieving a good cf is:
(a) very tight and clean B+
(b) high gm and low impedance tube
(c) adequate dc current
This time I would like to try 12B4a, which is a high gm and low impedance triode. As a cf, it is better than ECC88 in theory. It is much cheaper too. As far as I know, output impedance of a cf is 1 / gm * u / (1+u), so it can achieve an output impedance of 130 ohm.
I do think that a LM317 ccs at its cathode can improve the 12B4a cf too. If it can work, I will probably try connecting a high quality output transformer to its cathode via a 4uf capacitor. As such, the output impedance can be much lower. It is similar to a parafeed line amp., but this time the output is taken from the cathode, not the plate.
This is what I am thinking of and what I want to try. I think the experiment is worthwhile as both 12B4a and LM317 are cheap.
So can anybody give me some TECHNICAL advice as to implementing a LM317 ccs at the cathode of 12B4a as a cf? If it can work properly, I think it can be applied to other similar tubes that I have. Thanks in advance.
Just my cents. Please feel free to correct me if I am wrong.
Old 31st May 2006, 04:15 PM   #9
Default Re: Caution about using 12B4 as CF
Originally posted by Brian Beck
Usually you look for both high gm and moderately high mu for a CF. This is because the voltage gain of a CF is limited to mu/(mu+1). If mu is, say, 30 or higher (as in a 6DJ8) this factor is very close to one (about 0.97). With a low mu tube like the 12B4 (one of my favorites for common cathode use, BTW), this factor becomes 6.5/7.5 = 0.867. While this 1.2 dB loss may not be a problem, it does open the possibility for more second harmonic distortion since mu is now "more in the picture". Said another way, there is less negative feedback available for the CF. Whether this is sonically a problem or not is arguable. The 12B4 cathode output impedance (ignoring Rk for the moment) is about 1030/7.5 = about 140 ohms under data sheet bias conditions, and probably closer to 200 ohms under real world conditions. This is not bad, but a 6DJ8 can muster half of this value. As a side, if using a current source in the CF cathode circuit, I would NOT use a naked LM317. It's OK bypassed for common cathode service, as I showed earlier. You can use an LM317 with a simple cascode element (BJT, FET) above it to raise the output Z of the CCS at all frequencies. This gives the stability and predictability of the LM317 current setting based on a band-gap reference voltage and the cascode's multiplication of the output Z.
Hi Brian,
Thank you for your informative reply. You are correct, as a cf, ECC88 will be better than a 12B4a. I will look for a high gm and moderately high mu tube for a cf.
I am very interested in what you have proposed in the current source in the cf cathode circuit. As I am a layman to the solid state component, can you elaborate more (such as what cascode element) and sketch me the circuit if possible if I want 20 to 30 ma current.
Thanks.
TC MA
Old 31st May 2006, 04:52 PM   #10
hi TC,
why not U try the 5687??
looks if U like to try the CF 5687 will be a good choice. I had some experience about the CF with different tubes.
MF with OPT.
EC8010, 6c45,437a,417a/5842, EC900,EC86,EC88.
double triode I was try the ECC88,ECC86,5687& 5965. for CF stage. But I guess that 5687 & 5965 looks better than ECC88 & 86. Regarding running large current (approx 15ma~25ma) of the tubes. The damping looks quite good.
But the best performance that I prefer was use CF with the 600Ohm:600Ohm pre-amp OPT.
I was in Hong Kong. hope we can discuss more detail. I hope to share more experience that we had.
In my new DAc, the tube buffer was use EC900CF with the 600Ohm:600ohm. I choose EC900 beause this tube max only running in 11ma. I choose running in 150V, 7ma for the tube buffer with the 1541a DAC. So the pre-amp OPT will not too large.
If U try the parafeed had good result, pls let e know.
pls free to call me 93443443.
thx
thomas
cathode follower vlljpior Tubes / Valves 6 22nd March 2005 07:50 PM
Question about direct coupling a anode follower into a cathode follower. G Tubes / Valves 45 29th July 2004 06:47 PM
cathode follower ackcheng Tubes / Valves 2 6th July 2004 03:12 PM
cathode follower olvrkrg Tubes / Valves 3 21st February 2004 09:49 PM
Page generated in 0.12720 seconds (91.00% PHP - 9.00% MySQL) with 11 queries
