diyAudio Sponsor
Old 31st May 2006, 09:38 PM   #11
CBS240 is offline CBS240  United States
CBS240's Avatar
Default Re: Re: Vintage radio
Originally posted by rcavictim
Did you inherit the tabletop pedestal horn loudspeaker that this radio likely needs to be heard? I believe those were fairly high Z so don't expect to be able to put a modern 4-8 ohm loudspeaker on there and hear much of anything.
BTW I searched under vintage radios at ebay by chance out of curiosity about a weel ago and saw quite a few of the style radio you have, and their horns.
Like this one? This is a different radio my grandfather also had. I believe it is not as old, but there are more spider webs inside it than tubes! BTW, another future restoration project.
I don't know if that horn is any good though. Would it be possible to use a transformer to match speaker impeadence to a modern speaker?
Edit: I found a tube number. One of them had it printed on the base.... Radiotron(RCA) UX-201-A. I believe some have been replaced at some time...in 1931 according to the labels on the tubes. There is another tube #, CX-301-A.
Edit2: the 301 tube is aperently the same as the 201.
Thanx
All the trouble I've ever been in started out as fun......
Old 31st May 2006, 09:58 PM   #12
Originally posted by CBS240
OK, I have removed the back so the bottom of the chassis can be seen. It appears there are large coils underneath. Are these those awful paper/wax caps or inductors? This is completely foreign to me as this radio is older than anyone on this forum I would say...... since I have no documentation. It is obvious that it uses an external PS as there are wires from the back of the case labeled +B, -B, +A, +B DET, +B135, -C 4 1/2, A-C+, and B+AMP.
Those huge coils are probably inductors, they really can't fail seeing as all they are is just a huge coil of wire. I am not personally familiar with Transmiting radios, I do mainly AM/FM, but those coils are used to help adjust the frequency the radio is picking up.
someone please feel free to shut me down on this hunch if I am wrong, but are those inductors that huge because the radio was made before the invention/industrialisation of Ferite core Inductors?
Old 31st May 2006, 10:13 PM   #13
CBS240's Avatar
Some quick research finds that this tube base was first used in 1925.
http://www.radiomuseum.org/tubes/tube_ux201a.html
Old 1st June 2006, 12:32 AM   #14
lndm is offline lndm  Australia
Originally posted by Tom Bavis
I see a plate that says "Neutrodyne" - there's a Garod Neutrodyne listed here, but it only has four tubes... http://www.nostalgiaair.org/Resources/161/T0000161.htm
There are two schematics in the pdf. One is called a model EM, and has five valves. I noticed Kevinkr suggested yours might be a model M.
Old 1st June 2006, 03:44 AM   #15
CBS240's Avatar
Yes I believe it is! It is labeled "type M" Which may stand for this type of circuit. The reciever part of this scematic looks quite similar to what I have observed inside. 3 coils, two transformers, 5 triodes. I haven't pulled the reverse engineer method yet though. Hmmm, could it be the correct scematic? Can't seem to find much documentation with any specs though. Suppose I may have to pull it apart and look.
Also, does anyone have a good method for testing these type of tubes? I have a buch of small power transformers I can put the secondaries in series to obtain just about any isolated voltage. They may or may not be any good. It appears a couple of tubes have been replaced, there are some made under Cunningham's name and others are labeled from Radiotron, all from RCA.
Old 1st June 2006, 06:05 PM   #16
kevinkr's Avatar
Most Hickok tube testers will test the 01/201/301.
These have a 5V filament at 250mA, and are direct heated.
This radio dates from sometime in the second half of the 1920's. AC powered sets started to appear around 1927. (I have an ac powered radiola 18 made that year)
Chances are if this radio was not used for too many more years those tubes are still good. I have pulled high hour 01s on several occasions and they have been weak to good, never totally bad except if open filament. Keep your fingers crossed, the 01/201/301 are far less common than the 26, and fairly expensive when you can find them new.
Aircoils were used because low loss ferrites for rf were still a few years down the road when this radio was made.
I saw some mica caps in the photo, these are probably still good. I have a bunch of used ones I got for a shortwave breadboard radio I am building - they were just fine. (Using Cunningham 301)
I suspect this radio might be in (near) running condition, I'd deal with the psu issue first, see if it runs, and them repair as necessary.
Sometimes the audio interstage transformers in old sets go open, this is particularly the case if the set was ever stored in a damp location. AES sells a replacement bobbin that in many cases is adaptable to the original core for about $12 last time I checked.
AES probably has a power supply kit that can be adapted to power this radio. You may also be able to find people selling these on eBay.
Modern speakers even with transformers don't have the requisite sensitivity. Most of these radios are hard pressed to produce 100mWrms at maximum power and would sound pretty bad doing it.The old horns had massive amounts of acoustical gain, resulting in typical sensitivities equivalent I roughly estimate at up to 110dBspl or more at 1W.
www.kta-hifi.net
Old 18th May 2007, 07:56 AM   #17
EICO Model 666 will test your old tubes, and probably the Model 625 will too. Or for sure the Model 667 with 615 socket adaptor.
Some of that style tube had the number (type) on the side of the base, some on the top of the glass. To read faded numbers try first chilling the tube in fridge or freezer. When brought back to room temperature the tube sweats and the number may magically become visible for a short time.
Vintage Car Radio Identification? 65blkbkgt Car Audio 2 22nd June 2010 04:02 PM
Looking For Output Transistors For Vintage Car Radio 65blkbkgt Car Audio 14 29th May 2010 01:58 PM
Wanted: Vintage radio schematic - Philips B5CA66U (India) Dr. Ram Everything Else 3 23rd June 2008 03:24 AM
Vintage Delco R-675 automobile radio 405man Everything Else 2 16th December 2007 05:53 PM
vintage cd-80 honsten Digital Source 1 31st July 2004 06:29 PM
Page generated in 0.10013 seconds (80.90% PHP - 19.10% MySQL) with 11 queries
