diyAudio Sponsor
Old 30th May 2006, 09:19 AM   #1
colin.hepburn2's Avatar
Default PSU Rebuild Help Pleas
Hi All
PSU rebuild for Single Ended Headphone Amp
C.L.C.R.C R.C
First Cap 5.uf all others are 22uf 400 volt
Can i use polypropylene caps in stead of the electrolytics
As the caps are of small values 22uf @400volts
Colin
Colin
The Blues Man
Old 30th May 2006, 11:30 AM   #2
janneman's Avatar
Location: Where Germany, The Netherlands and Belgium meet
Default Re: PSU Rebuild Help Pleas
Originally posted by colin.hepburn2
Hi All
C.L.C.R.C R.C
Colin
What exactly is your question?
Jan Didden
/Another new issue: Linear Audio Volume 3!
Old 30th May 2006, 12:05 PM   #3
Default PSU rebuild
Hi All
C.L.C.R.C R.C
I want to replace the electrolytics
with the Solen ppe Caps but not sure if this is good or bad idea
Colin
Colin
The Blues Man
Old 30th May 2006, 12:35 PM   #4
janneman's Avatar
Default Re: PSU rebuild
Hi All
C.L.C.R.C R.C
Colin
It's a bad idea for your wallet. Other then that, you most probably won't notice it.
Jan Didden
Old 30th May 2006, 04:48 PM   #5
kevinkr's Avatar
Post a schematic and perhaps we can tell you whether or not it will make much of a difference, and which ones to replace for maximum price/performance benefit. In general there shouldn't be any problem provided that there is sufficient space available and the voltage rating is equal to or higher than the caps being replaced.
Incidentally Solens and a lot of other film caps are easily damaged by a wayward brush with the soldering iron so be careful!!
If you buy them from the right place solens aren't so expensive, and unlike electrolytics - if used within ratings really don't wear out.
In most 0 fdbk SE designs I've encountered the quality of the supply caps is audible, and contrary to popular belief I don't think this is a particular advantage, but a short coming of the design approach (very limited PSRR) or additionally an inditement of the quality of most EL caps. (I STILL prefer actively regulated supplies designed to have uniformly low source z across the audio band for this reason.)
JM2CW
www.kta-hifi.net
Old 30th May 2006, 05:03 PM   #6
Yes you can use polypropilene caps in stead of the electrolytics
types.You should hear if are there some improvements with normal one and eventually change again with Solen or other brand.
The question is how good is the design of your PSU?
It's a random one or it's a real design with calculated values?
Personally I think Solen are a waste of money, If your PSU is
a good project normal polyprop (Wima , Philips or other good product) are the correct ones.
Ciao cicero32
Old 30th May 2006, 09:28 PM   #7
Ciao cicero32
Hi All
Thanks For yore help
Cant seem to upload the Pics
You Can See the schematic of the Se Headphone Amp And the New power supply Hear http://uk.msnusers.com/MyAudioPics/shoebox.msnw I'm not sure if the psu is good pleas advise
Thank all
Colin
Colin
The Blues Man
Old 1st June 2006, 12:10 PM   #8
Default My Headphone Amp PSU Rebuild Help Pleas
Pleas advice on My SE Headphone Amp PSU
Thank you
Colin
Colin
The Blues Man
Pleas help!! LM386 Davide82 Chip Amps 3 19th June 2004 10:27 PM
Audiopoetry - pleas add Esra Yeknom Everything Else 0 20th January 2004 01:57 PM
Ontario Guys pleas read. nikonfanatic Pass Labs 12 5th September 2003 04:49 AM
how to calculate xfomer power, Pleas Help Christian Solid State 1 30th January 2003 09:05 PM
Pleas Help!!! PSU for LM3886? Christian Solid State 7 6th August 2002 01:49 AM
Page generated in 0.11353 seconds (78.18% PHP - 21.82% MySQL) with 10 queries
