| diyAudio Sponsor | ||
I was just given a Fisher 800 receiver, and am wondering what to do with it. It basically works, and actually sounds pretty good. It has an intermittent fault that makes the sound go away for a few seconds. It has the usual scratchy pots, etc.
As far as I can tell, it's the original 800, not the 800B, or 800C. Any recommendations? What's involved in restoration of these? I've sent email to fisherdoctor, but no response yet. |
#2 |
Naughty boy!
Eli D. |
#3 |
Well.. thanks.
I searched for fisher 800, and fisher restoration, but it didn't show up. |
#4 |
.. it gets more interesting. (well, to me, at least..)
After playing for about an hour, the intermittent sound loss in the right channel morphed into an intermittent farting noise, very loud and unpleasant. Gets more frequent as time goes on. I switched it off to cool down for a while. When I switched it on again, I thought I noticed a blue flash coming from the back somewhere. Power cycled it again, and more flashes, accompanied by ths sound of arcing. Gonna leave it off now, before it goes completely south. All this makes me want to take my time and get it working properly. While I was able to listen, was very impressed with the sound, especially vocals. Also "Lush Life" was very good. The FM sound is beautiful. Didn't try the AM. The phono stage hums in the left channel. Overall, I think it has great promise. My only other tube experience was to build a Bottlehead kit. That went fine, and I liked the result. This thing is of course in another league entirely. So many tubes! |
#6 |
You will find it helpful (nay, essential!) to have a schematic and parts list. I have scans of the Fisher servce manual and the Sams Photofact folder for the 800 (also called TA-800). Copies will cost you an email - tbavis(at)rochester(dot)rr(dot)com.
#7 |
Eli,
thanks. I did find the thread by searching on Valveitude. How should I proceed with the arcing problem? I don't know what was arcing, but am guessing it was one of the tubes. Maybe I should open it up, and power it on again so I can see what's arcing. Is the arcing likely to have damaged something? Tom, thanks for the offer. I sent you email. I'm not going to do anything until I see the schematic, and know what I'm looking for. Neil Baylis |
#8 |
Tom,
got the schematics today, thanks very much. Now to study a bit, and see what I can manage to get working. Neil |
#9 |
Getting back to this project after clearing up some other priorities.
I bought 4 new 7591s, but haven't tried them yet. Because of the light show in the original set, I was concerned that I might have burned up an OPT. If that was the case, I'm not sure I would want to go any further with this project, so my first order of business was to see if the OPTs were OK. I pulled all 4 7591s, after marking which is which. I measured the resistance of the OPT primaries through the tube sockets, and they seem fine. I can see about 190 Ohms resistance between the two plates of each pair, and about 140K resistance to ground in parallel with about 220 uF. Looking at the schematic this all seems reasonable, so I think the OPTs survived the fireworks. Next I powered up the amp (still without the output tubes) and measured the voltages in the tube sockets. The plate voltage, marked as 370V on the schematic, measured 420V. The grid measured somewhere between -9 and -10 volts. I thought the high B+ might be because the output tubes were not there to load it down, so I picked the best looking pair of the originals, and plugged them in. The voltage came down to about 400V, so I imagine with all four plugged in it would be reasonable. But the grid voltage is a bit weak. Later today, I'll see how far I get by replacing the selenium bridge. I've read Valveitude's thread about a million times, and got lots of good info. Since I begin with a dead output stage, I'm going to work from the output (and power supply) back to the input. |
#10 |
As expected, replacing the bridge with Shottkys did the trick. The bias is now -15V.
So I thought it would be OK to.. you know, put the new output tubes in. Wouldn't ya know it.. I bought the wrong ones. I got the EH 7591As, and they are too big for the space available. More anon, when my JJ tubes arrive. |
| Fisher Tube Tuner Restoration Walkthrough | LinuksGuru | Tubes / Valves | 7 | 15th November 2011 02:15 PM |
| Energy 22 Ref Con Restoration | bigerik | Multi-Way | 87 | 4th May 2011 03:00 AM |
| Gibson EH 150 restoration | mattnorthrop | Tubes / Valves | 15 | 26th March 2009 08:09 AM |
| DC Restoration -- book? | BottomTime | Chip Amps | 2 | 20th January 2005 07:35 PM |
| CD Restoration | Stryder | Digital Source | 5 | 2nd March 2003 12:06 AM |
| Page generated in 0.12042 seconds (80.62% PHP - 19.38% MySQL) with 10 queries |
