Bogen 8417 tube conversion..? - Page 4 - diyAudio
Old 4th June 2006, 11:38 PM   #31
Nichols is offline Nichols  United States
Default M120 Schematic
Thanks once more to those kind enough to reply. The schematic is too large to upload to the forum (660K). If anyone would like a copy please email me personally and I'll send it along.
Old 4th June 2006, 11:40 PM   #32
poobah is offline poobah  United States
poobah's Avatar
I believe the image hosting sites will accept pdf's. Post your pdf there... copy the URL/link... and embed it here.
www.imageshack.com
Edit: O.K. that's poor example... but there are others...
Old 5th June 2006, 12:09 AM   #33
Default Bogen M120 Schematic Image
Thanks to poobah, good idea.
If all goes correctly, the schematic should be here:
http://www.uploadfile.info/uploads/71c4fcbd7b.jpg
Old 5th June 2006, 12:13 AM   #34
poobah's Avatar
alright!
you da man.
Old 5th June 2006, 12:16 AM   #35
I think we could loose the mic inputs off the batt.
Old 6th June 2006, 12:37 AM   #36
I just can't believe all the ideas coming across on this thread.
I have seen more action in a graveyard.
Old 6th June 2006, 12:40 AM   #37
anatech is offline anatech  Canada
anatech's Avatar
Hi Joe,
What were you doing in a graveyard?
I think a direction decision would be good, or more questions ....
-Chris
Old 6th June 2006, 12:47 AM   #38
poobah's Avatar
Well Joe, grab the bull by the tail!
What tubes will drop into the 8417 sockets?
Look like all he would need is new cathode bias...
Old 6th June 2006, 12:58 AM   #39
I emailed Triode Electronics and received this much:
"...the 8417 tube is a high power beam power tube and you probably could convert to 6550 pretty easily. The tubes both have the same pinout so you wouldn't have to rewire the sockets. the 6550 cannot handle quite as much screen voltage so I'm not familiar with your circuit but you may have to drop that a little..."
That's all, maybe it's helpful.
Old 6th June 2006, 01:04 AM   #40
poobah's Avatar
And I think the idling plate current needs to be dropped
The plate voltage seems way high for a 6550 as well
Where are the tubeheads???
Quicksilver 8417 conversion Burnedfingers Tubes / Valves 25 18th December 2011 10:33 AM
Another Bogen CHB 100 Conversion dwdw Instruments and Amps 0 26th March 2009 12:46 PM
Bogen CHB-35 to conversion to B-12/B-15 hearforever Tubes / Valves 0 12th January 2008 07:48 AM
Bogen CHB-10A Conversion, need help and advice Turbo7MN Tubes / Valves 14 22nd August 2006 02:29 PM
Another Bogen Conversion Turbo7MN Tubes / Valves 12 20th May 2006 11:55 PM
Copyright 1999-2017 diyAudio
