| diyAudio Sponsor | ||
Hi Everyone,
I was lucky to get two Sansui OPT's and a PSU trafo from a friend. They were sitting on a shelf in his garage, collecting dust. Anyway, the OPT's are the same ones that were used in the Sansui AU-111. (410-5235) Originally, they were used with 6L6GC's in PP. They don't have UL taps, but have a 10% Cathode Feedback winding. Primaries are 4K, secondaries 16 and 8 Ohm. Power rating is 50 Watt. The PSU trafo is not from an AU-111. Secondaries are: 0-330V, 0-330V, 0-87V, 13-0-13V, 0-6.3V. VA rating is unknown. I have been contemplating triode strapping EL34's. But my speakers are 88dB sensitive, so I probably need more power. Alternatively, I could just build an AU-111 clone. (power amp only). But this calls for 485 Volt on the plates. I could get a Sansui PSU trafo copy made, but would like to use my 330V iron. Can the current production 6L6GC's handle 485V well? Could I perhaps use the CFB with EL34's in pentode mode? As a relative newbie, my mind is spinning. I would love to hear your recommendations. I've posted this question at AA, and got interesting replies. But I still feel unsure... Thanks in advance, Chris |
#2 |
Here's the Sansui AU-111 PA schematic. Not sure if it's worth cloning.
#3 |
I personally don't feel comfortable putting 485v into a 6l6gc (I figured out the dangers the hard way). Officaly, an El34 can handle 485v but that still seems a little high
#4 |
would KT88's or 6550's fill the bill? They will get get you the power want...
Use a choke in the PSU and bring it down to 400-420 |
#5 |
The AU-111 is a good design, and 485V at reasonable currents is not totally ill advised for the 6L6GC, I would certainly recommend subbing the 7581 which IMHO is better sounding and a little more rugged as well.
Not a bad circuit to clone at all IMHO.
www.kta-hifi.net |
#6 |
Thanks for the advice everyone.
I am quite attracted to KT88's. Poobah, do you mean KT88's in triode mode? I can source KT88EH tubes locally, but am wondering if JJ's would not be a better bet. What driver/phase-splitter circuit do you recommend? "The Ultimate PP KT88 Amp" driver looks nice, but calls for 480V. I have a few nice 6SN7's for this application. http://www.plitron.com/pages/Products/Audio/vtvkt88.htm Anyone have experience with the 6L6EH? Would it handle the 485V in an AU-111 clone? My dilemma: Building an AU-111 clone calls for a new PSU trafo. Using my 0-330V iron would free up money for more costly KT88's. Chris |
#7 |
How much power are you after? I don't think that triode mode will get you there...
#8 |
35W+ would be very nice indeed. Triode will give me half that, but is easier to build. Were you thinking of using the KT88's in the AU-111 circuit with 485V B+?
#9 |
35 Watts means NO triode mode.
I had no plan... Just 4K primary fits well with 6550/KT88... I know that 6550s will give you 35 Watts with your PSU tranny. SY is one of the guys to want to ping here... I am a tube nube myself. I am pretty sure that SY has not fallen into the SE abyss. |
#10 |
Hi Chris,
The sight of the Sansui iron made me drool I have an AU-111 which I want to revamp but I am struggling to find a clear schematic of the whole receiver. Do you have the complete schematic scanned? I would really appreciate a copy of this if you do have it on your computer. |
| Iron learning. | Tweeker | Tubes / Valves | 112 | 19th February 2008 08:56 PM |
| Gun or Iron? | mashaffer | Tubes / Valves | 13 | 29th December 2007 01:22 PM |
| HOT Iron ? | Vespasian | Tubes / Valves | 23 | 2nd November 2006 12:36 AM |
| soldering iron | jaudio | Parts | 15 | 17th March 2006 07:22 PM |
| For those of you in the UK who need a new soldering iron | 5th element | Parts | 2 | 26th March 2004 10:58 AM |
| Page generated in 0.12687 seconds (81.13% PHP - 18.87% MySQL) with 11 queries |
