diyAudio Sponsor
Old 27th January 2010, 01:22 AM   #91
rman is offline rman  Canada
rman's Avatar
Hi.
See Edcor electronics for your output iron. cheap and good. Or good and cheap.EDCOR - Browse Catagories
Cheers.
Rolf.
Old 28th January 2010, 01:21 AM   #92
bobluis is offline bobluis  Argentina
Originally Posted by rman View Post
Hi.
Cheers.
Rolf.
Thanks, Edcor is new to me. Apparently the model for this SE amplifier should be:
CXSE25-8-5K
Single-Ended Output Transformer
25 watts single-ended output transformer, 5,000 Ohms to 8 Ohms.
Best regards from Argentina
Old 1st March 2010, 04:41 AM   #93
just finished building this amp, and need a resource for trouble shooting. Is there any general values and procedures that I could refer to, in tracing down the problem. I follow the audio signal to the coupling capacitor and then loose it.
Frustrated
Old 1st March 2010, 11:58 AM   #94
Hello, I found this site very usefull for the first power up issue
Paul Ruby Amplifiers
Best regards
Roberto J Luis
Old 25th June 2010, 02:25 AM   #95
In the original Boozhound 6V6 Primer Tube Amplifier article it was used a 275 volts secondary transformer to obtain about 250 V B+ in the output stage. The power supply drawing shows 175 V.
Something is wrong here, usually the transformer are specified in RMS values. I need 200 V RMS in the secondary (282 V peak) to obtain, with the chosen rectifier (5y3 before PI filter) about 250V to feed the circuit (0,9 of peak value).
Do you agree?
Thanks, best regards
Old 25th June 2010, 02:39 AM   #96
aardvarkash10's Avatar
PSUD2
Yes, conservatism thrives on low intelligence and poor information. But the liberals in politics... continue to back off, yielding to the supremacy of the stupid. It's turkeys all the way down. - George Monbiot, guardian.co.uk, 6 Feb 2012
Boozhound Choke Tail Pair for HiFi mashaffer Tubes / Valves 4 14th June 2010 03:25 AM
First post, first project RH84 Dingleberryefxs Tubes / Valves 4 17th July 2009 11:20 AM
good begginer project (ax84 v.s. boozhound) eisenhower Tubes / Valves 9 4th May 2008 02:46 PM
TL quandry (post is not the project ) Madmike2 Full Range 44 10th May 2005 07:36 AM
Page generated in 0.08734 seconds (73.99% PHP - 26.01% MySQL) with 11 queries
