diyAudio Sponsor
Old 25th May 2006, 12:22 PM   #1
jim is offline jim  Belgium
Default What tube instead of 7189
Hi All,
I've got a pair of output transformers of an old Pioneer SM83 amplifier.
I would like to use 'm with another tube than the 7189 (or EL84M) they were designed for.
The PP-7189 delivers 18W at 400V so I think I can use some beefier tubes than the EL84.
Any suggestions? 6L6 - 807 ???
Thanks,
Jim
Old 25th May 2006, 12:27 PM   #2
SY's Avatar
7591 or 6L6.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 27th May 2006, 12:00 AM   #3
Hi jim ,
First of all , you have to say if the output transformers are wound for
UL operation ( 5 primary taps ) or for Pentode operation ( 3 primary taps ) , because the impedance plate to plate , are very different case
to case ( aprox. 40% ) .
If you know how to do it , calculate the TURNS RATIO : Primary plate to
plate versus secondary 8 ohms output and report the values .
Then we can recommend the best replacement .
Regards ,
Carlos
Old 27th May 2006, 08:24 AM   #4
Carlos,
Transformers are for pentode-mode only.
Raa = 8k.
Greetz,
Jim
Old 27th May 2006, 08:13 PM   #5
Miles Prower's Avatar
Since you have 18W xfmrs with an Raa= 8.0K, these would be ideal for use with 6V6s.
Operate Class AB1, Vpp= 285Vdc, Ip= 70mA, Vgk= -19Vdc. This will give 14W with 3.5% THD before adding feedback. Add local feedback + gNFB and that would perform quite well. 6V6s get considerable praise for sonic excellence.
There are no foxes in atheistholes
www.dolphin-hsl.com
Old 27th May 2006, 10:23 PM   #6
Tom Bavis's Avatar
It may be possible to run these at a higher voltage and power, but the low end will likely suffer from transfomer saturation. It's always OK (and usually better) to run at lower power.
Old 28th May 2006, 07:57 PM   #7
Hi JIM ,
First of all , I think that there is a little mistake , because 7189’s , connected as push-pull pentodes , with +B 400 V , and loaded
with 8000 ohms plate to plate , can deliver more than 25 Watts ,
with 4% THD , and not “only” 18 Watts , as you said .
So I think that , your output tranny can “hand” more than 24 Watts , without core saturation.
I’ll gave to you many suggestions , as follows :
6V6 – 1% THD
PP – Class AB1 – 12 Watts
Plate voltage : 350 VDC Screen voltage : 340 VDC
Max. at each grid control : 13 Volts RMS ( signal level )
COMMON cathode resistor : 250 ohms x 10 Watts
6973 – 2% THD
PP – Class AB – 24 Watts
Plate voltage : 400 VDC Screen voltage : 290 VDC
Control grid : ( - ) 25 VDC
Fixed bias
6BQ5 / EL84 – 4% THD
PP – Class AB1 – 17 Watts
Plate voltage : 300 VDC Screen voltage : 290 VDC
Max. at each grid control : 10 Volts RMS ( signal level )
COMMON cathode resistor : 130 ohms x 15 Watts
6CZ5 – 1% THD
PP – Class AB1 – 22 watts
Plate voltage : 350 VDC Screen voltage : 280 VDC
Control grid : ( - ) 23.5 VDC
Fixed bias
6L6 GB / GC / WXT , etc. – 2% THD
PP – Class AB1 – about 24 Watts
Plate voltage : 360 VDC Screen voltage : 270 VDC
Control Grid : ( - ) 22.5 VDC
Fixed bias
Note : In this case , the ideal load would be 6600–7000 ohms plate to plate , but 8000 ohms still works too .
Note 1 : The values of THD ( harmonic distortion ) are without
negative feedback , with NFB , the values will lower 10
times or more .
Note 2 : KT66 , 7591 , 807 and 5881 , need to be running under
Ultra Linear operation condition , to be loading with
8000 ohms plate to plate .
Note 3 : 6CA7 / EL34 can deliver more than 25 Watts , so , your
output tranny , will have core saturation and distortion.
Any doubt , feel free to ask ,
Regards ,
Carlos
Old 28th May 2006, 08:27 PM   #8
Fixed bias
How do you figure this? The 807 and 6L6 are the same VT in different bottles. Same Q Points and everything. The 807/6L6 are not good for ultralinear (which I don't like anyway) since this VT was intended to run with Vpp up and Vsgsg held down. You don't get much with them in ultralinear (~10W). You bust the R(L) spec that much, and you aren't going to get ~2.0% THD anymore.
www.dolphin-hsl.com
Old 29th May 2006, 03:42 AM   #9
Hi JIM ,
First of all I want to say to Miles Prower , that 6L6 and 807
“ARE NOT THE SAME TUBE IN DIFFERENT BOTTLES”
They have some common characteristics , but you NEVER
can say that they are “the same tube” , as you said .
Second :
I NEVER affirmed on my previous post , that 6L6 and 807
are good tubes for UL operation , you did not understand .
What I had said , was the following :
“The 807 and others , MUST to be in a UL circuit , to work fine
with a load of 8000 ohms , ” ( 8000 ohms is the input impedance
plate to plate of JIM’s output tranny , and as he said it is only for
pentode connection , then , 807 and others , are not useful tubes
for him )
JIM ,
All technical characteristcs and suggestions that I had sent
on my previous post , has like base , the following bibliography ;
RCA 28 – Receiving Tube Manual
SYLVANIA – Technical Manual - 1954 Edition / 1958 Edition and
1970 Edition
Radio Amateur’s Handbook – 1939 Edition and 1952 Edition
Regards ,
Carlos
Old 29th May 2006, 05:15 AM   #10
[B]Hi JIM ,
Not just "some common characteristics", but identical Q Points, power out, and THD figures. In another thread, Tubelab said he took apart both types and found no internal difference. Just a couple of nights ago, I also found a schematic for a CW xmtr that used a 6L6 as the final in a circuit identical to one used for 807s.
Second :
for him )
You also said:
6L6 GB / GC / WXT , etc. : 2% THD
PP : Class AB1 : about 24 Watts
Fixed bias
Note : In this case , the ideal load would be 6600 -- 7000 ohms plate to plate , but 8000 ohms still works too .
Not word one there about UL, implying that he could use the 6L6, but not the 807.
www.dolphin-hsl.com
7189 vs EL84 +458v plate kkillebrew Tubes / Valves 7 28th January 2009 11:27 PM
7189 or 7819 el84 tube? papanohn Tubes / Valves 6 24th March 2007 04:37 PM
7189/7189A Problem Victoria Tubes / Valves 6 22nd January 2007 03:08 AM
"The Fisher" tube amp 7189 output tubes laflamme Tubes / Valves 4 28th August 2004 12:40 AM
7189 in pentode mode? G Tubes / Valves 30 12th March 2003 04:13 PM
Page generated in 0.13629 seconds (81.48% PHP - 18.52% MySQL) with 10 queries
