diyAudio Sponsor
Old 24th May 2006, 02:07 PM   #1
EsE is offline EsE  Norway
Question Audio Note M3/4/5/6/8 schematics
Hi there!
I tried to ask for Audio Note schematics in general in a thread, but got no replies. So now I'm asking for schematics for AN M3, wich I'd like to clone.
EsE
Old 29th May 2006, 08:45 AM   #2
I would avoid audionote circuits, they sound poor, due to poor transformers, and in the pre's, thick with rolled off treble.
Audionote are going down the tubes, too, no-one will supply qvortrup.
Old 29th May 2006, 08:34 PM   #3
Ok, what else are you suggesting?
I really like the AN sound, I think the treble sound natural; not extended to sound "hi-fi". And I can use a different transformer, I'm open for suggestions here as well.
Old 30th May 2006, 07:39 AM   #4
mach1 is offline mach1  Australia
mach1's Avatar
Unfortunately, If you build AN preamps to the original designs with parts other than those used in the originals (esp transformers and capacitors) they tend to sound very sonically challenged.
Some of the designs are downright weird: how about a linestage using a 6072 SRPP into a paralleled 5687 ? If you email me I can send you a few schematics, but if remember correctly they don't contain many component values, and if they do they are often wrong.
Old 30th May 2006, 07:15 PM   #5
I'm going for almost all the original parts. Half the joy of making your own amp is tweaking!
The 6072 srpp into a paralelled 5687 is almost a m10. I've got the scheme for that one, and that is probably the amp I'm ging to build when the time comes.
How do I send PM's on this forum? Can't find a way..
audio note dac 1.1.x schematics val65 Digital Source 1 20th January 2009 07:50 PM
Audio Note Soro SE SCHEMATICS rokauskas Tubes / Valves 0 5th August 2008 12:53 PM
FS: Audio Note TRANS-010; Audio Note 20H 50mA choke; Black Gate Wk "power tank" Joseph0 Swap Meet 1 24th May 2006 05:17 AM
Audio Note schematics EsE Tubes / Valves 0 22nd May 2006 10:10 PM
Looking for Audio Note P1SE schematics. zulmr2 Tubes / Valves 2 15th October 2005 03:28 PM
Page generated in 0.07525 seconds (76.81% PHP - 23.19% MySQL) with 10 queries
