diyAudio Sponsor
Old 22nd May 2006, 08:49 PM   #1
Mr. Triatic's Avatar
Default Data for PE08/40
Hi all!
i´m looking for any kind of data on Philips PE08/40
i cant seem to find anything on google, nor in my tubelists/books..
pls. help, any info would be welcome!!
www.joddla.net/audio/
Old 23rd May 2006, 05:43 AM   #2
Tubes4e4's Avatar
No hint in RTT or the Ratheiser book either. You are sure on the "08" part of the designation? PE06/40 just would be 807 ...
Tom
If in doubt, just measure.
Old 23rd May 2006, 07:01 AM   #3
Yes i am pretty sure it says 08/40, PE tells me its a tetrode, right?
i will try to take a picture tonight, the tube has two anode connections on top, not ordinary caps but nuts to tighten wires in place.
Old 23rd May 2006, 08:30 AM   #4
Tubes4e4's Avatar
"PE" is just an old Philips/Valvo prefix for transmitting tubes, as far as I know not giving implicite information on wether it might be tetrode or pentode. Since Philips had the pentode patents, I suppose many PE types were real pentodes w/ surpressor grids, indeed.
Tom
Old 23rd May 2006, 08:56 PM   #5
here is the picture:
Old 23rd May 2006, 09:53 PM   #6
coresta is offline coresta  France
coresta's Avatar
an old RL12P35 relabelled
Old 23rd May 2006, 10:12 PM   #7
ach so.. relabeled.. -Thank you very much for the info!!
it seems suitable for audio, dont you think? 8-)
Old 24th May 2006, 06:45 AM   #8
coresta's Avatar
Ja , but the results are not so good as other RS (Sendung) tubes . And did you ever tried to find the socket ?
Old 24th May 2006, 07:20 AM   #9
i think i have a few sockets already..
but i guess im sonically better off with 6DQ5 or PL/EL509 in SE right?
-but linearity of RL12P35 is not that bad for a pentode?
I know its not kinkless, but anyhow, it is usable!
Any recommendation for OPT:s?
B&K ST-202 Data Chris Screven Solid State 1 7th April 2009 11:46 AM
Data from my FIRST DIY TurboFC3S Multi-Way 10 17th December 2006 04:28 AM
FRD & ZMA data foo Multi-Way 4 21st August 2004 10:45 PM
Help! I need TRW(UTC) O35 DATA purer Tubes / Valves 0 26th February 2004 04:35 AM
Need GU-81m data woody Tubes / Valves 2 20th June 2002 09:08 AM
Page generated in 0.09088 seconds (74.63% PHP - 25.37% MySQL) with 10 queries
