CF and SRPP in one circuit . .
Old 21st May 2006, 02:35 PM   #1
rick57 is offline rick57
Default CF and SRPP in one circuit . .
. . is there a sonic price?
What do our learned people think of this:
Meant to be flexible, one here said ****:
Old 21st May 2006, 08:43 PM   #2
Geek is offline Geek
Geek's Avatar
Sonic price as in....?
Old 21st May 2006, 10:43 PM   #3
Apologies for my shorthand.
I meant:
in providing switching between a classic common cathode-cathode follower cascade (CF) and a shunt-regulated push-pull (SRPP) circuit (it also has a passive path) in the one circuit, is there anything about this circuit that would reduce transparency/ transient response etc, over separate CF and SRPP circuits?
Any advice appreciated
Old 21st May 2006, 11:08 PM   #4
mod_evil is offline mod_evil  Brazil
mod_evil's Avatar
Send a message via MSN to mod_evil
Is a SRPP circuit with 6sn7GT a good circuit?
Old 22nd May 2006, 12:48 AM   #5
Geek's Avatar
I meant:
If you use a good switch or relays, nothing that you'd hear response wise. Though unless you use a multiple deck rotary (expensive) or relays (cheaper), stereo seperation can suffer.
*budda, boom ching!*
A mate has good success with a 6SN7GT SRPP in tubifying his tuner output
Old 22nd May 2006, 12:58 AM   #6
cogsncogs is offline cogsncogs  United States
cogsncogs's Avatar
No, not really, save for some minute capacitive coupling in switch SW3 and sharing a common PS. And also combining the miller input 'C' of the two separate stages, esp the CF coupled stage, minute or not as it may be. Some may have a problem with all those nasty, dirty switches in the signal path.
Me thinks this was designed to compare CF & SRPP. The passive will have some HF attenuation because of the 100k level and volume pots, depending on their settings and your interconnects of course!
Wayne
Sent from my Linux desktop computer using a keyboard and a mouse.
CF and SRPP in one circuit . .Hide this!Advertise here!
Aleph circuit is Single, SEPP ,SRPP or other ? SkyChu Pass Labs 8 18th June 2011 04:38 PM
SRPP circuit question pwgtang Tubes / Valves 20 22nd July 2008 04:25 AM
Replacing cathode resistors of Aikido 1st stage (or other SRPP circuit) with chokes snoopyma Tubes / Valves 1 31st July 2006 06:21 PM
mu / srpp / or CF? AudioGeek Tubes / Valves 9 24th April 2004 06:48 PM
SRPP is....? peranders Tubes / Valves 8 19th December 2003 09:38 PM
Copyright ©1999-2017 diyAudio
