| diyAudio Sponsor | ||
Hi
Anyone with experience with using battery (2x 1.2V NiMH) on the cathode of 6C45pi, 417, 437 or similar, driving a 300B output tube? Some says RC (in parallell) is better sonic wize? Agree? Pros, cons and comments much appreciated. Cheers, Tom, Norway
Higher end! |
#3 |
I agree with SY. To directly answer your question, I believe the battery is the preferred choice. In particular, there is a lack of bass rolloff (mainly a lack of phase shift) that gives the bass a much cleaner sound IMO. This effect resembles one improvement that LED's offer.
#4 |
Hi Sy,
that sounds very interesting. Could you be so kind to enlighten me on the subject? Simple schematics if possible and what you have of experienced. Best, Tom
Higher end! |
#5 |
Hi Tom, I'm playing around with that configuration on a couple of amps - a 6C45-KT100 (soon to be GU-50) and a 6C45-EL84. It's the all-purpose front end.
You might find the attached graph interesting. It's zipped to get past the forum size limits without reducing resolution. It shows a spectral analysis of a 6C45 biased with two series green LEDs and an IXYS solid state current source for a plate load. The output is driving a 100 kohm resistor at about 95 volts peak-to-peak. The operating conditons are as specified in the PNG's name, 3.9 Vdc grid to cathode, 5.4 ma plate current. This places the plate at ~200 Vdc, nominally 50 over limit. I've had no issues, this tube is tough as nails and others have abused it much harder. Static plate dissipation is barely a watt, less than 20% rated. THD is about 0.2% as shown and nearly pure second harmonic. The junk above 10 kHz is a measurement artifact. The LEDs are unbypassed. Bypassing with a 1000 uF cap actually brough the 3rd harmonic up a few dB. The LEDs' internal resistance apparently generates a little negative feedback. It had almost no effect on the 2nd. This will be as good a starting point as any at driving a 300 with a single stage of 6C45. Don't most 300's bias around 100 Vdc? Four volts bias on the cathode doesn't leave much headroom and the gain of ~40 will require significant drive voltage from the source.
Ears aren't microphones. |
#6 |
Thanks for your good inputs!
I don't have a CCS on my 6C45pi, but I am using a beefy PSU with LCLCRC with BG and grid choke; running 12mA. I am not a tube specialist, but can I substitute my NiMH 2x1.2V battery with one LED with Vf about 2V for improved sonics? I don't think I will go for CCS now, perhaps later. Cheers, Tom
Higher end! |
#7 |
Here, here!
My Tri-amp (300B/10Y/50) uses 417/5842 as the driver and I must say I'm a recent convert to the LED bias I changed the cathode resistor to LED (Orange) that gives me 1.9V on the cathode. I should say the improvement is unbelievable for just two LED. Mine is unbypassed, by the way. My 45 amp with the same driver was the first conversion. |
#8 | |
on your site that line is gray .......
my Papa is smarter than your Nelson ! tnx to thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
#9 |
choky!
re: 10Y- I've heard a pair at a friend's house driving a vintage Altec and has glorious mids. After that I searched for them tubes Anyway, since I liked the 5842 as a driver and the grid voltage to drive is it similar to the 45 (in fact a bit lower) I thought it would work out just right. I got it to sound to my liking in this prototype - And I used it for months, until friends saw them and thought they're ugly. So I looked for a "nicer" chassis which I posted at the pictures section of diyAudio (bad pic actually) In the end I was gifted a pair of 50, made sume adjustments and I posted the project here - My simple 5010 amplifiers I guess that's the story and thank you for reminding me that I don't have anything about that project on my site |
#10 |
Here they are now in a "nicer" chassis-
It uses a 417A variant- the Amperex gold pin 5842 and now uses LEDs on the cathode. My 45 uses plate choke on the drivers but in this chassis I don't have a place for another transformer so I will be putting in a pair of diyAudio's CCS boards in a coming experiment. Why the 417A (and variants)? 1) Simple to implement (1 tube) 2) Have balls as a driver |
| We417+300b | China_Vincent | Tubes / Valves | 34 | 6th February 2009 08:14 AM |
| Determing Battery Voltage for cathode bias | jeffdavison | Tubes / Valves | 8 | 13th August 2008 04:26 PM |
| Battery for Cathode Voltage? | markw51 | Tubes / Valves | 15 | 12th December 2006 02:53 PM |
| cathode battery bias questions | zobsky | Tubes / Valves | 6 | 3rd June 2004 01:47 AM |
| 'Battery under cathode' bias - long-term users? | Saurav | Tubes / Valves | 5 | 10th November 2003 01:24 AM |
| Page generated in 0.11115 seconds (78.40% PHP - 21.60% MySQL) with 11 queries |
